Well I tried
Exactly why I did’t order Safari’s. I figured the potential for issues on a new vehicle were high enough without guaranteeing one.
I liked the extra space, and was considering taking the glass frame parts off and replacing the glass with a AL sheet with radio mounts welded on, and putting ham up there. But, it turns out, its the first sunroof I've had that I actually like to use. So, I picked up the RHD left side A pillar cover to access the grab handle holes, and am going to fabricate a cross bar above the dash to mount radios/ipad mini to.
It's not a matter of time. Its just a few OZ of water sitting there. there's no stack pressure. Someone isn't doing their job and pissing on your leg.
Mine is proper tight and it still leaks
Tomorrow I'll post the solution my dealer did that seemed to fix the problem. PACNW gets it's share of rain. No issues post fix.
Mine will not leak unless parked on an uphill slope of approx 9⁰. Have you done that overnight in heavy rain without leaks?
My seals have been changed many times, are fixed in with black silicone. The glass shut has been made much tighter and it still seaps in between the glass and the seal at the back parts
You are in America. American MY24s were European MY23.5. (or even MY23)
That's not at all accurate, our MY24s have a number of updates and different hardware than Euro MY23s.. our PTO2 vehicles were effectively European MY23s (those of us working the PTO2 tour were some of the first to test the 1940 software revision for the MY23 headunits), the PTO2.2 vehicles (early dealer demos and press vehicles) were coined "MY23.75" because they had a hodgepodge of MY23 and MY24 hardware, but did not have ADAS, and our MY24s are again revised. Beyond that, MY24.2 (VIN 17000+) are again different, we also have MY24.3 which was at the end of production of the model year
So if I’m looking at a vin 18xxx it would have the newest appropriate changes?
The seal on the frame looks pinched on the last photo. I would take out the rubber seal, clean up, reseal with black silicone etc and refit the seal or new one. Needs reseating again.
Dealer has done this numerous times, I will request it's done again.
They are contacting IA for advice
You have some hardware revisions in comparison to the MY24.1; but then there are some changes for MY24.3 and MY25.1 (and MY25.2, assuming they stayed on the naming structure).
I'm not sure what you mean by appropriate changes though.
I’m looking at a 17xxx (‘24) and a 25xxx (‘25)and was trying to understand what differences there may be between the models. I realize there may be small improvements so I’m trying to understand what those may be and if it’s worth a premium price.
I'm going to guess no. The only issue I would have, is if its a shorter term purchase, the MY will bite you on resale. If you're a 10 year kinda guy, I'd hop on the rebates and rates of 24 if it was what I wanted.
I’m a 20 year guy.
Reactions: CRH
The differences between the 24 and 25 will not make any changes in the long term
I’m a 20 year guy.
Mines a 24. They did the door handles, the update, fixed the rear alignement issue. I still have a weird zf8 clunk downshifting 3-2, but theres only a few of us. It's not a bigger issue. I dont see an updated 24 as missing anything important a 25 has.
any news on this?
Here are pictures from today. Some on how it looks with them closed and then window out. You will notice they went wild with the sealant and even used the sealant on the rubber grommet that leads to drain hole. Since I was up there, I did clean around the seas with just water. I have a sunroof cleaner kit that I will use as fall wraps up. I also use canister of compress air to blow down the drain holes from time to time.
Here are pictures from today. Some on how it looks with min close and then window out. You will notice they went wild with the sealant and even used the sealant on the rubber grommet that leads to drain hole. Since I was up there, I did clean around the seas with just water. I have a sunroof cleaner kit that I will use as fall wraps up. I also use canister of compress air to blow down the drain holes from time to time.
Makes me happy I opted to order without safari. Just one more leak waiting to happen.
That sealant application looks like a blind person did it.. wtf!?
