Trickle Charger hookup location
Amazon page in the US for this charger. Sold by Amazon.
Weird, it doesn't state if it runs on 110v or not. I suspect it does but who knows.
I ordered one, I like the features and the price was right.
I did order the big c80-li, the price delta was $30 and I thought it was worth it.
Delivery in October...
I guess as it’s priced in dollars on a US Amazon site it will work on 110v. In the U.K. the Amazon listing states that it comes with a UK style plug.
I just checked out the C80Li and I like the power supply feature. Could be useful
Ineos official answer regarding smart/trickle chargers. They recommend a Bosch C7 12v 7amp battery charger which has a six stage profile.
Not much info online and can’t find a new one for sale in the uk. Looking at the Bosch website for C line chargers and there is no C7 only starting with C10. It seems these are designed to be used with EFB batteries whereas most other manufacturers don’t mention EFB. The good thing with these is you don’t need to decide which battery type you have it will start a gentle charge and decipher for itself what battery type you have. The various models all charge upto 120ah batteries and some do LiFe-PO4
I have a Victron smart charger permanently wired in , so that when when I get to a powered camp I can connect my mains lead, which then powers the smart/trickle charger, fridge then automatically switches over to mains power and any any other mains powered kit can be powered up without the need for an inverter. I’m tempted to get a Bosch charger as I can take out the Victron smart charger that I have and re use else where on other kit. The the solar mppt controller that I’m about to install can go where I have the Victron charger. And I can permanently wire in the Bosch charger in a different location. Deciding on the C40Li model as may be adding a Lithium house battery when I get to kit out the inside.
The C7 charger is likely obsolete. I'd stick with a C30 or above (like your intended C40Li) so you get memory function. You don't want to have to dig your way under the rear seat to set the battery type every time you want to top off the batteries.
Using the Noco (sometimes overnight) will raise the charge level on our single battery substantially (95-98%). But it seems to take a little while to register the actual charge level once you're running again. If I run a few short trips it seems the state of charge will increase a point or two every time I restart where as normally I'm going in the other direction after short trips.
I don’t have an AGM setting on the Victron chargers I own. It’s either normal, high ,Li-ion and Recondition. I use the normal setting which does an absorption charge at 14.4 volts as I’m not sure if the high setting at 14.7 volts is too high or not. It seems there are different types of AGM as well so I’m taking that it’s a basic AGM until I know different. Just for an idea here is a screen shot from the Victron mppt controller manual When I add my solar and Victron mppt controller I’ll use the no 2 setting which does an absorption charge at 14.4 volts until I know better.
My solar mptt Victron has a custom setting, in addition to the default 4. You can then specify the voltages and stages. This is done via the Bluetooth interface to their app on your phone.
For a battery maintainer I went the CTEK route they really make it easy with their pre-fab pigtails for under the hood and cable extension kits. I attached the charger to a nearby workbench and plugged it into an integrated multi-outlet power strip so I can easily turn the charger off with one switch, disconnect the plug from the pigtail under the hood and hit the road.
I did put a black wiring loom on the pigtail to protect it and make it a bit more factory looking under the hood. Also, I’m sure I could have poked the pigtail through the grill or somewhere else to avoid lifting the hood but I didn’t like the idea of the plug being exposed directly to the elements or visible dangling through the grill or something similar.
Yes I’m not confident I know enough about batteries to start messing around in the advanced settings so I stick to the defaults.
Yes unfortunately that’s happened to a few owners. This happened to me last year. First photo taken 1052hrs and the second at 1053hrs. Go figure that out. 😂. Hasn’t happened since. My vehicle is regularly left for days and sometimes weeks connected to a smart charger.
That's some reassurance then that the 0% happens to others (I guess). Was worried I hadn't grounded the Gren properly and damaged something. Guess I'll see what has happens when I get back to the Uk in a couple of months
Nicely done, thanks for the photos. I bought the NOCO 10 & extension after looking at CTEK, can't remember why. Will buy the pig tails for it next time as makes sense having it permanently installed.
USE THE CORRECT CHARGING PROFILE ON THE TRICKLE CHARGER
If you are using a trickle charger on the MOLL EFB battery make sure the charger is set to the correct charging profile.
Moll's EFB recommended charge rate is 14.4 volts and the maximum is 14.8 volts for its EFB batteries. Make sure the charging profile you choose is compatible with that. More information here:
WARNING: do not use any regeneration or recondition mode or repair mode on the charger, as they often exceed the max voltage of 14.8 volts.
Is there any particular reason they picked this battery?
I've never came across an efb battery before.
Can it be replaced with an AGM battery is needed when on the road? Does the charging system care?
Interestingly Molle make an AFB which is similar to an AGM and Molle market it as a disguised AGM ! Now given that there is no EFB PLUS battery listed on their website, this battery is almost certainly an OEM specific product and must be an enhanced version of an ordinary EFB. Maybe Ineos has had this made so it has specific configurations for the Grenadier and similar to an AFB? Also if you add in the answer I got from a contact at Ineos UK who is a lead tech and qoute ;- “Although it is an EFB the charging profiles operated by the Vehicle ( BCM and smart charge system) operate as an AGM profile.” Maybe we have something that has similar characteristics to the Molle AFB but branded by Ineos as EFB -PLUS ?
Food for thought
I don't like these bespoke custom components. None of them. A vehicle of this nature should be built to take as wide a set of aftermarket components as possible, specially consumables like batteries.
I guess someone will come up with a bracket to just use standard off the shelf ones at some point
I’m with you. A vehicle for the world and remote travels needs to be able to use off the shelf pattern parts in my view.
Can I feed in a trickle charge via the 12v power outlet if the overhead 'power' switch is on?
I mean the rear one, since it seems to be associated with that switch. I've not tried the other one, for any purpose, but either would be fine. Ultimately I just want a simple non-permanent setup which trickles power into the battery if I'm parked outside for an extended period. This worked well enough with my old jeep and a panel propped up inside my windscreen. But if they power things like sockets via power MOSFETs then its unlikely current will flow back to battery?
I would just run the charger's leads off the main battery, making sure the lead is fused. Then just plug the solar panel into that. Install the wires to the battery once and your done - based on image you posted.
I've hooked up to a trailer outlet. One of the pins there is always powered, fused for 25A at least as it seems. I also bought a trailer port <-> SAE adapter on Amazon, and it connects exactly to that pin, so any trickle charger with a SAE connector can be simply plugged in, and it will be enough to maintain the battery. The choice of the trickle charger is another thing. I have an old smart one, but its floating charge is about 14.9v, and that's way too much in my opinion. I bought a Noco Genius 5 instead, but a Genius 1 or 10 should work as well. They have proprietary connectors, but Amazon has a 20A fused adapter from Noco to SAE, and here we go - trailer port -> SAE-Noco adapter -> Noco, and it all fused and works. I like Noco because they are more conservative with voltage in maintenance mode and have a memory function for the last used charging mode. It even came with a wall bracket. Overall, no wiring is needed, easy to plug in and out.
Also, Noco clamps are not needed in this setup, but they serve as a perfect red flag reminder on the door handle! :)
To whom it may concern: tested this setup for two weeks while on vacation. Came back to battery at 94%, so assuming this works exactly as intended.
