Tool kit
Wow, I think it was a very good bargain! I had to pay in Sabie/South Afrika for a 1974 edition with the famous illustrations 28 Euro! But it is really worth it! Enjoy it! Hans
Result!
and my new multi tool to boot!
It may have been already posted, but one tool set I have used repeatedly on the INEOS is the Wera WER05056490001 Tool-Check PLUS Bit Ratchet, 39 Pieces. I have only had the car 5 days.
Ich trage das bei mir, wenn ich reise.
Since i had the tools out for the oil change this seems like the best time to post them . So i tried to build a robust kit that will potentially be able to cover 90% of things i will need to do to my Gren . Any time i wrench on my gren i make it a point to use this kit . In case i need something that is not in the kit /or does not work as i want then i will add it / remove it as time goes on . This is just the tool kit no it does not contain any spares. It will only be carried on trips ( not on a daily basis , since the Gren is my daily driver ) .
The kit it is in a kind of a tool roll . Laid out looks like this :
Each pocket has a theme to it so i know what i expect to find in there in a glimpse .
First pocket has pliers , squeeze things and cutting things (ignore the marker its just in case i need to draw a mustache on someone) :
Second pocket is the persuader along with all the poky bits and we cannot forget the thumb detecting nut f*cker (adjustable wrench) :
Third pocket we have sockets . I tried to find all the types on the Gren and here is what i came up with . External torx , torx , normal( hex 6 point deep and shallow ) . I know the seats are held in with tamper proof torx but I decided not to include them , they can work on normal torx also but the hole in the middle makes them more susceptible to failure so they are not included .
Pocket 4 is everything screw related plus a tire valve stem tool ( one in the car at all times with extra valve stems , if you know you know )
Last pocket is the miscellaneous: allen keys , test light , epoxy paste , random hose clamps and a pair of strippers.
On the reverse side is a full set of combination spanners .
All packed up looks like this :
Hope it gives someone ideas . Show us your tool kit and what you have in it !!!
Bumping an old thread. I just read all 25 pages and with the exception of sniping, lots of good info.
@Tinki can you update us on what you’ve added and subtracted since you posted this? I really need to put together a kit and this thread certainly is a great resource.
Agreed on that @Krabby Specifically I need to know what I don’t need in my kit, as I’ve probably got too much.
Carrying a full socket set is the biggest overkill. And don't omit the correct hose clamp tools, soldering iron and, and ... :)
I’ve never really got to the bottom of exactly what size sockets and spanner’s I need and then there is the thought in my head, what if I need to help someone else ? I’ll take this just in case 🤔
Many of us are of that mind set. If you also have a caravan you pack a rivet gun, screws , hinges , locks, clasps, jackstands, plumbing fittings and plenty more besides the drill, impact gun , angle grinder, chainsaw...
Unless you are seriously DIY you won't need to flex a giant spanner and socket set.
I like to have a go at most things. I begrudge paying someone to do things I can do myself. Some say it’s being tight but I say resourceful.I definitely want to be able to do a bush fix of the Grenadier whilst out in the field.
I stopped to help and loan these guys some tools in Mauritania. They were so grateful and I enjoyed the banter. Also I’m a great believer in “what goes around comes around “
This post has some common used bolt heads types, with downloadable summary Tables of various sizes commonly used. See also Rok Dr Guide paragraph 9.9 and Table 14. Having tools to handle these is a good start.
My most used tool kit is the Wera WER05056490001 Tool-Check PLUS Bit Ratchet Kit (39 Pieces), followed by a couple of KNIPEX PLIERS WRENCH (180mm and 250mm models). I wish I knew about the Knipex years ago, they are so versatile.
81xbqfv8vql-_ac_sl1500_-jpg.7881759
Hello Everyone ,
Sorry for the delay in replying .
Load out additions are :
Koken spinner for tyre removal + the rim socket
2x knipex wrenches ( these will go up to 58mm) enough to cover all bases )
i added a set of circlip pliers
i added 3x of these magnetic small led lights in the car really help when you get out in the middle of the night to wrench .
I upgraded my epoxy putty to a waterproof one .
lastly i added an old fluke multimeter i had lying around . ( overkill ) but why not .
These are the exact items i have and carry .
Again you do not need to buy name brands, i try and buy the best i can afford because i want to buy once . Cheaper sets should do the same .
Hello Everyone ,
I’ve never heard of Koken tools but those knipex adjustable pliers and wrenches are the mutts nuts. I have a selection.
Koken tools are not very popular , but they are very good quality , i would put them up there with snap on and stahlwille.
Another nice japanese brand if you are into tools and shiny stuff is nepros.
Knipex has been my go to ever since i found a set of side cutters at a flea market in Germany ages ago made in W. Germany . Fine quality , i was sold on the spot . Something about them is really satisfying to use . Germans know how to make good tools .
Nearly same tool setup, Wera, Knipex, Gedore all good german toolbrands, ~50km are all plants around me AND possible to buy via my employer on wholesale price 🤗 -> more tools as needed at home
We should organize a tool buying roadtrip !!! can we fit a gedore rolling cabinet at the back of the grenadier ? Asking for science . ahahaha
I picked up this tool bag off of Amazon this weekend. You can't fully load it but it fits quite a bit of kit and once "balanced" properly it fits under the seat quite snug. I have my socket set, torx bits, screw driver set, multi meter, soldering iron, wrench set, spare wire, loctite, electrical tape, hex keys, mini ossicilioscope, punches, plier set, snap ring pliers and adjustable wrenches packed.
