Result!Wow, I think it was a very good bargain! I had to pay in Sabie/South Afrika for a 1974 edition with the famous illustrations 28 Euro! But it is really worth it! Enjoy it! Hans
and my new multi tool to boot!
Bumping an old thread. I just read all 25 pages and with the exception of sniping, lots of good info.Since i had the tools out for the oil change this seems like the best time to post them . So i tried to build a robust kit that will potentially be able to cover 90% of things i will need to do to my Gren . Any time i wrench on my gren i make it a point to use this kit . In case i need something that is not in the kit /or does not work as i want then i will add it / remove it as time goes on . This is just the tool kit no it does not contain any spares. It will only be carried on trips ( not on a daily basis , since the Gren is my daily driver ) .
The kit it is in a kind of a tool roll . Laid out looks like this :
Each pocket has a theme to it so i know what i expect to find in there in a glimpse .
First pocket has pliers , squeeze things and cutting things (ignore the marker its just in case i need to draw a mustache on someone) :
Second pocket is the persuader along with all the poky bits and we cannot forget the thumb detecting nut f*cker (adjustable wrench) :
Third pocket we have sockets . I tried to find all the types on the Gren and here is what i came up with . External torx , torx , normal( hex 6 point deep and shallow ) . I know the seats are held in with tamper proof torx but I decided not to include them , they can work on normal torx also but the hole in the middle makes them more susceptible to failure so they are not included .
Pocket 4 is everything screw related plus a tire valve stem tool ( one in the car at all times with extra valve stems , if you know you know )
Last pocket is the miscellaneous: allen keys , test light , epoxy paste , random hose clamps and a pair of strippers.
On the reverse side is a full set of combination spanners .
All packed up looks like this :
Hope it gives someone ideas . Show us your tool kit and what you have in it !!!
Agreed on that @Krabby Specifically I need to know what I don’t need in my kit, as I’ve probably got too much.Bumping an old thread. I just read all 25 pages and with the exception of sniping, lots of good info.
@Tinki can you update us on what you’ve added and subtracted since you posted this? I really need to put together a kit and this thread certainly is a great resource.
Carrying a full socket set is the biggest overkill. And don't omit the correct hose clamp tools, soldering iron and, and ...Agreed on that @Krabby Specifically I need to know what I don’t need in my kit, as I’ve probably got too much.
I’ve never really got to the bottom of exactly what size sockets and spanner’s I need and then there is the thought in my head, what if I need to help someone else ? I’ll take this just in caseCarrying a full socket set is the biggest overkill. And don't omit the correct hose clamp tools, soldering iron and, and ...![]()
Many of us are of that mind set. If you also have a caravan you pack a rivet gun, screws , hinges , locks, clasps, jackstands, plumbing fittings and plenty more besides the drill, impact gun , angle grinder, chainsaw...I’ve never really got to the bottom of exactly what size sockets and spanner’s I need and then there is the thought in my head, what if I need to help someone else ? I’ll take this just in case![]()
