- Local time
- 6:43 AM
- Joined
- Sep 26, 2021
- Messages
- 236
- Reaction score
- 63
bestextra said:Anyone have an idea of the real clearance under the diffs? The prototypes look quite low slung, and almost certainly not 10.1”/257mm under the diff.
Unfortunately manufacturer-quoted “ground clearance” has been abused to the point of being meaningless: https://practicalmotoring.com.au/car-advice/why-arent-4x4-manufacturers-clear-about-ground-clearance/
I’d be disappointed if Ineos are similarly fudging the numbers.
It is 10.1" - 10.4". I crawled underneath the prototype and measured it..because I felt the same that they 'looked' too low. I also measured the trailing arm and radiator bottom points and they are indeed 10"+. This is with the vehicle on 265/70 R17 (31.5") tires. Slap some 33" on and the clearance numbers will improve even more.
