Software Update!
Got mine back from the dealer last week after the software update was installed. Things I’ve noticed:
  • Over speed warning does not reset after a key cycle. Good.
  • The low fuel warning at 75 miles (amber message) is not accompanied by the loud chime, but the red warning still is. Good-ish.
  • On my drive home, the radio would turn on by itself. If I had Apply CarPlay on and hit the mute button, it would stay off. F I had the radio on and hit the mute button, it would come back on after a couple minutes driving. Strange…
  • Just last night after fueling up, the trip meter MPG would not display a value, just the “- -“ lines. Did the same thing this morning and has not displayed a value since. See image below. Not so good.
Which update? 24.1 or 24.2+
The update is now available for all cars. I have the earlier version. I'm at the dealership right now and it just got updated. It takes 1.5 hrs and there is only one update (not separate for newer vs. older models).
Not sure if this is related to the software update or perhaps a new gremlin.
Apple Car Play will no longer read whatsapp messages anymore. I can reply via Whatsapp and it will read out what I’ve spoken to it as a message, but if a message pops up and I click “read” it just skips it and then asks “do I want to reply?"
Any one else had a similar issue.
I have tried resetting the dash via holding the Mute button.
This has been going on for around 3 days with multiple car restarts in that period.
Does the trip meter work after you reset the trip?
Just picked mine up- I almost miss the aircraft like start up procedure.
Got my ride back, SOOOO much nicer just getting in and hitting the only common button across many brands (except some) ASS and driving off. I think overall the drive was much quieter no dings random bongs or engine lights coming and going. lol Fuel gauge looks a bit more accurate too me anyway.
So apparently my update didn't stick. Sat over night started up same ole same ole with errors. Called dealer back up they said that the headunit update has been struggling on other customer cars as well. With Ineos system is down right now so they can't even do the full flash??? So you can get the update via a 30 min fix to the headunit some stick some don't but then after the headunit flash they typically do the full flash which can take 5hrs. However they didn't get to that on my ride since Ineos wasn't working at the time. Just thought I would share.
