Underside view.
Point taken, there are additional bracing point to be added once the form factor is finalised. As you know there is always a balancing act of strength versus weight. I suspect the tensile bolts will give way first. Your feedback is appreciated.I'm not an engineer but I could see some longitudinal bracing being helpful. Maybe a couple of small triangles welded in between the arms and the tanks? Taking a hit on the leading face of the tank while traveling at speed might do more damage to the tank structure than landing on an obstacle at slow speeds. Just a thought.
When do you expect to be selling them?Point taken, there are additional bracing point to be added once the form factor is finalised. As you know there is always a balancing act of strength versus weight. I suspect the tensile bolts will give way first. Your feedback is appreciated.
Just going through finalisation designs. There has been interest from a certain party that has changed some requirements (in good way). I will know a lot more after the weekend, as some discussions are being had on Saturday. I will make sure your are the first to know on the updates.When do you expect to be selling them?
Great, thank youJust going through finalisation designs. There has been interest from a certain party that has changed some requirements (in good way). I will know a lot more after the weekend, as some discussions are being had on Saturday. I will make sure your are the first to know on the updates.
Any chance that hilift jacking points could be added to them. That would be the icing on the cakeJust going through finalisation designs. There has been interest from a certain party that has changed some requirements (in good way). I will know a lot more after the weekend, as some discussions are being had on Saturday. I will make sure your are the first to know on the updates.
Any chance that hilift jacking points could be added to them. That would be the icing on the cake![]()
