Sill water tanks
Underside view.
I'm not an engineer but I could see some longitudinal bracing being helpful. Maybe a couple of small triangles welded in between the arms and the tanks? Taking a hit on the leading face of the tank while traveling at speed might do more damage to the tank structure than landing on an obstacle at slow speeds. Just a thought.
Point taken, there are additional bracing point to be added once the form factor is finalised. As you know there is always a balancing act of strength versus weight. I suspect the tensile bolts will give way first. Your feedback is appreciated.
