Sill water tanks
Underside view.
I'm not an engineer but I could see some longitudinal bracing being helpful. Maybe a couple of small triangles welded in between the arms and the tanks? Taking a hit on the leading face of the tank while traveling at speed might do more damage to the tank structure than landing on an obstacle at slow speeds. Just a thought.
Point taken, there are additional bracing point to be added once the form factor is finalised. As you know there is always a balancing act of strength versus weight. I suspect the tensile bolts will give way first. Your feedback is appreciated.
When do you expect to be selling them?
Just going through finalisation designs. There has been interest from a certain party that has changed some requirements (in good way). I will know a lot more after the weekend, as some discussions are being had on Saturday. I will make sure your are the first to know on the updates.
Great, thank you
Any chance that hilift jacking points could be added to them. That would be the icing on the cake 🤔
.that is one of the updates being looked at. I am conscious of not driving price through the roof. The length of the filter has a bearing on this as well..
Slight detour but does anyone know if the pak off-road the same as the front runner 40l tank they sell in the US?
