Same here: we are directly on the plastic strips to minimize dynamic movement. But as allread mentioned, we can go higher if somebody wish that.On the new rack, how many mm from the top of the plastic strips to the top of the new rack cross bars?
What sort of impact are severe corrugations for hours at a time likely to have on your setup @Black SheepSame here: we are directly on the plastic strips to minimize dynamic movement. But as allread mentioned, we can go higher if somebody wish that.
The best test would be a 1000km test on those corrugations!Wha
I’d be concerned that the constant severe bouncing with the rack in direct contact to the strips would either cause damage to the rack, strips or roof itself.
There are two different scenarios: Either the whole thing is compact and forms a unit with the roof construction. The advantage is that there are fewer dynamic forces, which means that accessories and the vehicle age less quickly. At the same time, it may be that the plastic strips wear out over time... The load even on the roof surface is definitely not a problem.Wha
Especially having navigation directions on the windshield - BWM does an outstanding job with their HUDsI haven't used this one Dave but my wife's BMW has a heads-up display and I love it
Sind diese richtig?Hallo an Alle.
Die Lüftungsgitter, die Nakatanenga für die hinteren Türen des Landy anbietet, passen auch prima beim Grenadier.![]()
Here here....Yes Ronny is good.
I have just ordered a single STEDI slimline light to test for this same idea.i am very interested in the lamps from lazer lights. i would like to mount lamps on the sides of the space under the roof handles, with a ring attached to the handle. would be very interesting if there is a solution here!
Let us Know how it fit‘s!I have just ordered a single STEDI slimline light to test for this same idea.
Hi Tom,Sind diese richtig?
They seem like good solution for parking when locked and in hot, sunny conditions.In the Old Defender they were for sure a good solution. But with electrical windows which I can operate from the driver seat, and with an air condition, I find them a bit useless, to be honest.
Thank you!Hi Tom,
they won't fit! They are about 2cm too short!
Yes, you definitely feel you are being worked. He's not even shy about it.He says controversial things to prompt people to like/dislike and to comment.
Likes and dislikes are treated the same and the more comments he gets the more money he makes.
That's why most Youtubers ask a question and say "leave your comments below"
I have just had a look at the Frontrunner slimline II roof rack system and it looks like it will suit the Grenadier nicely.
The cross rails can be located anywhere along the side rails, the side rails can be extended and the first few cross rails can be removed/slid back to allow the safari windows to open fully or be removed.
It is also fully off road rated unlike most roof racks that have to be de-rated by up to 40% for ofroad use.
Has anyone had one of these and any positive or negative feedback?
Yes, I think that will be my choice.
But it uses up 33% of your payload.On the subject of roof racks. I was chatting with the team at Ineos Cape Town and they reckon the Rhino rack as supplied by Ineos is by far the best roof rack for the Grenadier. When you look at the support legs for each side then each side is one piece that connects to the pioneer platform also each clamp contacts the full width of the gutter so no flexing of the gutter. As others have said a few thousand km of corrugations will sort the wheat from the chaff
