Removing door panels/ color of the speaker wires
Eric.S.
1:25 PM
Hello everyone;) Small question, has anyone already tried to dismantle the door panel or do you know what colours the cables from the speakers have? I would like to improve my sound system a little, I find the originals terrible... In the B column you would also have to get to the cables without dismantling the door panel? I just want to install a mini subwoofer under the driver's seat, the space should be enough;) If this question has already been asked, I apologise;)
I have been following various threads on speaker upgrades and tweeter positioning.
Had mine done yesterday (Focal flax Evo) and I’m super happy with the location and sound. Looks about as from the factory as I’ve seen.
I was looking at a similar location, an inch down and to the left where the leather is and it has a slight angle upward. Did you dynamat the whole door?
Upvote 0
Hello,
I'm planning to upgrade the front speakers too.
I'd like to avoid pulling the tweeter wires thru the rubber hose between door and frame,
Is there a change concerning to the pictures of the different wire colors to find the wire to the doorspeaker underneath the A-pillar without massivly destroying the covers of the cable harness?
If so, I'd like to install the crossover there and connect it to the original wires.
Regards Sauerländer
Upvote 0
Hello,
Regards Sauerländer
Hello @Sauerländer
There is a basic speaker + tweeter upgrade video here. He identifies the speaker harness and wire colours from 3:37. This is MY23 RHD but may be the same.
View: https://youtu.be/i7bmG33S0yQ?feature=shared
Upvote 0
where did you tap into the head unit? did you have a a specific "T" harness or did you make your own harness? if so, which connectors did you use?
Upvote 0
You can grab all four speaker outputs from a pair of connectors on the passenger side lower kick panel (bottom of the a-pillar). I'm sure a connector for these plugs is available somewhere, and that would make it easier as there isn't a ton of room to work with the wiring there
Upvote 0
