Power Steering failure
PaulBond
12:39 PM
Spain
Hi All
I have had the intermittent warnings of Power Steering Error" for about a year. These used to clear when using the now recognised Grenadier usual method of turning the thing off, beating it with a birch branch for at least 10 minutes (other types of tree may work) and then restating it. Fine. The dealer claims to know nothing of it and as always claims I am the only one on the planet with this problem.
However, at the weekend the steering failed, not error, failed. I could barely move the car with no power steering.
It now rests with the dealer, who reported that when it came off the recovery truck all was fine!
Anyone else had this?
Hi All
Yes I had exactly this in the first two months of ownership. Three times on a recovery truck. It was very frustrating 😡
First time the power steering fault could not be replicated at the dealers so a software update and reboot of the system was carried out. A couple of weeks later it happened again at a busy intersection with traffic lights. This time the “ gateway control unit “ was replaced. Again a couple of weeks a later and power steering failed again’ this time at a motorway service station. Another long wait for the AA. This time the fault was not intermittent but permanently disabled power steering. This time the power steering pump was replaced and has been fine for the last two years. The most frustrating thing at the time was the waiting for parts to get the issue sorted. I hope parts delivery is quicker now.
Good luck with getting the issue sorted.
Hi Paul,
I also hard this issue. In most of the cases it happens when starting the engine and I could feel the servo pressure going but coming back after a second. However the error message for the whole run or sometimes went away after some kilometers. However last summer it happened quite frequently while driving - power steering went off for a second and then came back. I was always anxious when it happened but at the end it was never a critical situation. In fact the dealer and also IA Engineering support thought it was SW/signal issue which it was not. At they end it was another hidden fuse box which most likely was defect from factory - new fuse box and now for six months no issues.
Can you add that to the Tool section of the forum?
When plugging plugs back in and wiggling fuses , and liberal applications of the obscene vernacular have no effect.
Best of luck getting it sorted. It all adds to the collective knowledge we can thrust at the head scratching service agent if needs be.
Thanks for the words of wisdom. Much appreciated. I am going to pass these on to the technical customer car person who emailed me today a week after my issues were escalated as urgent to "head office". Sigh....
Good luck and let us know how this is resolved
This maybe a long shot. I have seen battery terminals loose before. Make sure that both positive and negative is tight. If one of them comes loose on a bump, this may affect the electronics. This is the first thing I would check and whilst you at it, firmly push in all the fuses.
Hi Paul,
Thanks Pat. My dealer seems to be still waiting for Ineos Technical to help them with this, so I am hopeful of some action soon. Meanwhile I am left without a car...
Thanks for your help, the car is with the dealer now so it's in their hands
We are now five weeks without the car. Firstly, like you, they could not replicate the fault in the workshop. But when i said, OK, I'll bring it back to you when I have an accident due to failed steering, they took a slightly different tack. Firstly they diagnosed a faulty earth on the pump, caused by overspraying. That fixed they then reported in week three that there were additional faults found on the pump and despite emails and calls with the UK Technical representative and the Spanish dealer nothing more.
I did get a call from the dealership sales manager on Friday offering me a new Black Edition for my car plus €46K!
The saga continues.
The saga continues.
Why would anyone upgrade their car if they cannot rectify their existing issues unless it was for free. What an insult. Get them to put a new steering pump on pronto!!!
I hope they checked the battery terminal connections like I first said. I hope you get it sorted asap.
I had an old Jaguar once. Sometimes when hitting a bump, the headlights would go out…
I just picked my Grenadier up from the dealer (service overdue is cleared, pleasant surprise). My main concern to be checked out is fluid appears to be escaping the p.s. reservoir. They said this was common on Grenadiers and not to worry about it. I guess I have to put up with oily residue all over the engine bay.(?)
It's a vented cap. If the fluid is hot or the fluid level is high it's going to vent some mist. Agile sell a thicker cap o-ring supposedly to improve the sealing. Except it's a vented cap so 🤷‍♂️
I was going to look for a better o-ring or something. The engine compartment was dusty with road dirt since I bought it. Now it's oily, wipe your finger on the shine and get residue.
Exactly. A fancy O ring won't help.
Are you certain it's power steering fluid residue? What colour does it taste like?
If you're keen to isolate it, rag everything clean around it then tape a clear ziploc bag over the reservoir. No so tight that the reservoir cannot breathe but secure enough to keep the bag in place. If the inside of the bag gets filmy after a few days and everything around it outside stays clean you have your culprit.
I'm not sold on a phatter cap o-ring though. It's not a pressurized reservoir. Even if the o-ring was undersized there's no internal pressure to force mist past the cap.
