Noob 4WD: Locked Center Diff but only one wheel spinning in snow – Is this normal?
I much prefer a manual in snow because I find it a lot easier to regulate power and obtain feedback about traction. But . . . vehicles with automatic transmissions can be very capable in snow and low traction. For starting from a stop in extremely slippery conditions, the technique I'd often use is to select a higher gear to start. This reduces the amount of torque transmitted to the wheels and reduces initial slipping. Instead of slipping a manual clutch, I'm slipping the torque converter or clutch bands. Do this enough - like when you're stuck and trying to rock out of a hole - and you can absolutely burn up a clutch band that is nearing end-of-life (done that). So just like slipping a manual clutch, it needs to be done sparingly.
I used this technique everyday for several years driving to work in a '68 Plymouth Fury III in the early morning winters in Alaska. The Plymouth was a big 18' long 4-door sedan with almost no weight on the rear axle and a 318 with 230 HP up front. Going to work, I'd pull into a left turn lane that was aimed uphill with about a 3% grade. In Anchorage, the roads would get covered with ice and snow in October and stay that way until May. Left turns lanes were almost always polished ice due to lots of sliding stops, wild spinning starts (dumb drivers) and the heat of idling vehicles melting the ice and snow (which would immediately re-freeze). The technique to get moving without spinning was to manually select 2nd gear on the automatic transmission (or sometimes even 3rd gear in extremely slippery conditions ), let off the brake and let idle or a tiny amount of throttle get the car moving. There was almost always enough traction to move slowly - like at a slow walk. Try this in Drive (which would select 1st gear to start from a stop) and the tires would immediately break free and spin in place. Less informed drivers could hold everyone up as they madly spun their wheels, going no where through two or three light cycles before finally getting through the intersection by dumb luck.
Many autos won’t allow you to select the gear, rather they’ll let you select the maximum gear. It’s super annoying. I’ve been in road conditions where I want to select 2nd and curse the engineers that took that choice away from me.
100% - if one wheel was spinning, I don’t believe the center differential was locked. As mentioned, you’ll know it’s locked because of the indicator on the telltale board. But interesting fact - when you go to unlock it, when the light goes away, it doesn’t mean you’re totally unlocked. I had a nasty surprise a couple months ago where my engine went into limp mode on the highway. Turns out, when I unlocked my center diff about a week before after crawling out of a snowbank, it was not absolutely in the unlocked high slot. Enough not to grind, enough where the light went off - but about a week later, maybe a bump in the road or something and it thought I was trying to lock the diff at speed and so went into limp mode. Took my dealers mechanic a bit to figure that one out. You might THINK you’ve got it fully in the locked or unlocked position, but you can’t be shy with it. You’ve really got to make sure you haul that thing into position - go full-on exorcist with it, like you’re dealing with one of the Nine Princes of Hell. Your buddies may wonder why you are yelling “the Power of Christ compels you!” as you wrestle with your center diff, but the good news is they will probably all agree to let you have the tent to yourself and plenty of space to stretch out at the campfire.
(1) An open differential splits input torque equally between two outputs.
I'd say that's almost correct. An open differential will transfer the same amount of torque as the side with the least amount of torque to the other side. So if the driveshaft provides 100 Nm but the left tire can only make 5 Nm of torque against some ice, only 5 Nm will be transmitted to the right tire.
Oh my statement is correct without a caveat. The differential does not know what the tire traction is.
If the tire's traction amounts only to 5Nm, the other tire will only receive 5Nm, and the driveshaft will only provide 10Nm divided by the ring/pinion gear ratio (regardless of what it can deliver).
So it is exactly correct.
@pmatusov , I appreciate your precision – and yes, your axiom is correct as stated. But its incompleteness is exactly what generates the "endless blabber" you're frustrated by. A more complete explanation is likely to create understanding instead of continued confusion.
Your axiom states that outputs are equal, but it doesn't say anything about what sets the magnitude. That's the piece most people are missing. A more complete statement might be:
An open differential equalizes output torque at whatever level the low-traction side permits, with the input shaft supplying only what's needed to sustain that – and potentially accelerating the low-traction wheel with any surplus.
That framing does a lot more to clear up most of the confusion that frustrates you so.
Regarding your statement ". . . the differential doesn't know what the tire traction is" – I'd disagree with that statement. It's true the differential mechanism itself has no sensor. But the system as a whole – the ring gear, spider gears, output shafts, tires, and surface – reaches equilibrium entirely governed by the traction reaction at each contact patch. The spider gears can only build torque at each output up to the reaction force the tire provides. In that sense the system is very sensitive to traction, even if no one component "knows" anything. And that's precisely the mechanism behind misunderstanding how a differential splits torque – the system yields equal torques, but traction determines what that equal value actually is.
Misunderstanding how differentials work is widespread, sometimes including here. That seems like an argument for clearer explanation rather than less patience with the people asking.
It's certainly possible such transmissions exists, but I've never run into an automatic that wouldn't let me select a particular gear except when a gear selection is denied because the resulting engine RPM would exceed redline or some other rpm limit. Three speed autos have huge jumps in ratios, relying on the torque converter to bridge the gap. So shifting from D or 3rd down to 2nd can be a big jump in rpm.
I drive my Grenny in steep mountain terrain a lot. I often use manual mode to select a gear that will provide engine braking. Unlike a manual trans that can provide pretty aggressive engine braking that by itself is sufficient to decelerate the vehicle, in the Grenadier I use the brakes to get to a desired descent speed and then gear selection to hold that speed. Occasionally, as I’m braking to a desired speed, I’ll downshift a wee bit early and the ZF won’t implement my gear selection until the rpm drops a little bit more (even though it wouldn't exceed redline).
I assume you know the difference between an axiom and a corollary.
Many times I took time and effort to write more elaborate explanation to how open, locked, and limited slip differentials work. This time, I elected skipping the long discourse on the subject specifically knowing someone would come up with a response of that sort:
It's all pedantic. Nobody really cares.
If you think this clears up the fog:
... then I probably better shut up. I will make a correction, however:
A differential does not know what the tire traction is. It doesn't even know if it is in front, rear, center, or elsewhere.
