Light bar wiring to battery
samm88
1:26 AM
USA
Hello, I have a based Grenadier w/o high load auxiliary switch. I want to install a light bar but I do not know where to run the wiring from the roof to the battery. Does anyone what location where I could run the wiring? Ty
Ask @Telemark who has the same challenge (then let us know what you did):
There's a grommet behind the passenger side kick panel. Pull the plastic trim off in the footwell and you'll see it. Run your wires through there into the engine bay and over to the battery. It's the cleanest way.
Hi Samm,
I had the same issue and wired my quartermaster this past week. I used the ext 1 switch (10 amps) to trigger a 50amp Fastronix relay under the hood. I have the Ineos lightbar that pulls 25amps so used a 50amp relay. The ext 1 wires are under the hood on the left had side. Once you find those wires extend them with heat shrink butt connectors and 12 gauge wire to the relay. You will need a fused connector between the buss bar post (power is from the post that you use to jump start it) and the relay. I ran the cable from the engine compartment along the frame/ I have a quartermaster, so it was easy to run the cable between the cab and the tub, up the loadbars to the roof. Let me know if you have other questions and good luck.
