INEOS CAMPAIGN: trailing arm bolts being monitored
TheDocAUS
4:07 PM
Eromanga
I happened to look under the rear of my car today, from a distance, and I noticed something green. It was one of the recent campaigns done on my car. INEOS are monitoring whether the rear trailing arm bolt is coming loose. A brilliantly simple idea.
I am going to get myself one of those green pens and do the same on other bolts under the car, like those on my under car armour. A simple and effective way to visually monitor bolts becoming loose.
It will speed up checks on the car when traveling remote.
Great idea INEOS.
@Rok_Dr , @Logsplitter , @globalgregors
Great idea INEOS.
It's a common practice in many industries. Just use a paint pen or a medium point permanent marker. I do the same for critical fasteners on my camper; like the D035 coupling to drawbar bolts, suspension links, shock bolts, towball and nut.
There are specialist products like Torque Seal (I found some old stock in my shed).
Don't use the same green pen. That's the colour my agent used also and that cannot be a coincidence. Use a different colour for bolts that you mark so they don't get confused with an Ineos service campaign.
Those link bolts are a single use item. They're supposed to be replaced if they get removed. When that same campaign was done on my vehicle in July six bolts 'failed' a torque check so were replaced. It was odd that any failed and improbable that six failed. They're a substantial M14 bolt. I asked my agent how they did the torque check. I'll leave out the details and simply say, badly. Some bolts were replaced unnecessarily. A learning experience for a young apprentice...
Edit: Torque Seal inserted and pics added for reference.
Great idea INEOS.
The mechanic did the same to my Grenadier when I had the HD springs fitted, called witness marks
Edding 8750 Industry Marker
Used for all kind of markings on clean or dirty metall. I use them always to mark things.
Recently I used it on the pulley of my Rover V8. Should be temporarily....I needed a metal brush to get rid of it again.
Sad and worrying that this is necessary.
AWo
This. ⬆︎
I used a red paint pen on the small bolts holding the rear trailing arm protectors in place.
I've been working on one of our older vehicles this week - a 25 year old Jeep. There are green paint marks all over the under carriage. Little dots, slashes , and even an "X" or two on just about every component (yellow on the rear inner half shafts). Must've been a busy job for the inspector on the assembly line.
My 60s Benzes had those marks on critical components.
Do it once , do it properly.
Carry the marker (and some degreser) in the vehicle , so if you have to do something on a journey you know you've ticked the job off properly at the time.
I use the Dykem Cross-Check on every build I do where I need to keep track of things. It's better than straight paint for sure. I have several tubes in all my workshops.
The benefit of a specialty torque-seal product like I posted and @landmannnn also mentioned is that it can be removed with a plastic (preferable) scraper and doesn't leave any significant residue. It's a thin plastic bead that hardens when exposed to air. It's really intended for critical fasteners that get disturbed or torque checked semi-regularly during maintenance or repair hence the temporary nature. It's easy to remove and reapply when required.
For fasteners that rarely get touched but you still want a visual confidence check then a paint pen or a marker is fine albeit with a little more work to do to establish a new mark whenever the fastener is disturbed. Or, do as my agent did and use a new colour each time they messed with the trailing link bolts. In that sense they're being used as a QA check not a creep check, same as the factory marks.
I generally go a bit more OCD and don't use random positions for the witness lines but use a uniform pattern accross all fasteners sort of like a hidden signature that tells me it was my work when a vehicle returns to the workshop.
I've attached my DNA to many pieces of equipment. None of which were intentional. 🩸
Have done that many times. Helped a bloke leave the end of his finger in an engine years ago. He learnt fast to pay attention and piston and rod assemblies make a good guillotine in a Cat engine.
It's a real pain getting all the old <painted on with whatever was around in the workshop at the time> marks from the past.
Esp if you don't have a lift, and don't enjoy solvent running down your arm on in your eyes!
