On my car, they were added as part of an INEOS Campaign. I just jumped on board for other bolts, to make checks easier when I go remote.Yup used them for decades at this point in various spots. But have never known a dealer to add these ad-hoc. Which seemed like you were saying was done to your car? Mine seem to have these marks all over the place.
Many workshops work over several shifts and incomplete jobs are handed to a new tech. Many of the marks are a tell tale to indicate the task is complete for the oncoming tech, very common in truck and machinery workshops.Most modern vehicles have marks like this. Many valid reasons for it, none of which are alarming:
That last one was the case in Hambach. After the first full production batch of Grenadiers went down the line those vehicles went into a batch-and-hold process whilst a program of selected checks and changes was conducted. Depending on the VIN, that's where a lot of these marks came from, plus some random cable ties
- The QA team is doing programmed sampling checks.
- There may be a temporary monitoring program on specific locations after a non-conformance was found.
- There may be a procedure change on the production line and they're monitoring for implementation as the change works through.
- Technicians might apply their own reminder marks during maintenance. They should remove them afterwards but often don't.
- There may be a post-production QC program to catch-up changes on a batch of VINs.
If applied during or after production they're considered to be witness marks applied by an inspector. If specifically applied to intersect a fastener they're considered to be creep marks. If the formed line is broken something has shifted due to a loss of torque and should be investigated.
A creep mark system requires discipline to remove the old marks before applying a new mark or it loses value as a visual aid.
Unlike this example of my RHR lower forward link bolt. The inside (nut side) is different again.
But no chalkie numbers on the chassis rail (see my LR) or behind the dash, where you only find it 60+ years laterIf some one really looks around there is likely going to be random letters, numbers or symbols stamped near critical welds as part of weld inspections.
