104 km, first ownerHow many total miles on it? How long have you owned it? Any previous owners?
Sorry to hear this. New car should not be without a functional HVAC.104 km, first owner
I had this issue in my 24. Have you checked your coolant levels? Topping mine off and running the bleed procedure has fixed it for me.2024 Trialmaster 25k miles. All stock except for a roof rack. Coldest setting with Air compressor switch on, is cold...... next notch is VERY warm, anything to the "right" (clockwise) from there, and its just full heat. Basically no adjustment at all. Either you have air conditioning, or full heat. I have a 1995 F800 truck with a mechanical slide lever that works better than this. If they put the temperature sensor in the duct after the fan/damper controls, and let us set the temperature of the air coming THROUGH the system, it would be much better.
And more of the nanny state featureWould the HVAC issues make you all go with a 2026 over a 2025, even with around an effective $8,500 premium?
Someone suggested it was it a similar system to air source heating in a house, and we know how good they are if it's not 100% insulated and sealed upI have noticed the colder it gets the more likely the HVAC will fail to produce heat
