Build Thread The Lobster, DaneJa's overlanding build
They determined that they couldn't develop a solution to bolt on the OEM axels that would meet their standards. They collaborated with Currie Enterprises to make a Dana 44/60 hybrid axle for Jeeps and some version of that is likely what will go into the Grenadier package with braketry to match OEM mounting so it'll be bolt-on. Quinn posted a video about a year ago when gauging interest in a Grenadier package, but nothing has come out since.
Wow thank for the details I missed that one completely. Saying he needs some commitment, does anyone have a actual $$$ in mind here?
I will argue that if the technical capability of portal axles is needed then the Grenadier is not the correct tool for the job. A JL Wrangler on 37" - 40" tires is much more appropriate for rocky technical terrain with no need for a portal conversion only a moderate lift. At some point you are building a rock buggy. Not to disparage rock buggies, they are awesome, but it is not within the envelope of the Grenadier's design brief. Nor is the gearing of the Grenadier appropriate for the most technical terrain. The Greandier crawl ratio is 53.81:1. A JL Wrangler's crawl ratio is 77.24:1 with the OEM auto transmission and 4.10 axle gearing and can easily be increased to over 90:1 with a change to 4.88 gears. With the OEM manual transmission and 4.88 gears the crawl ratio is 100.14:1. The issue is that the Grenadier has only 2.5:1 reduction in the transfercase while the Wrangler is 4:1. Yes you could gear portals to acheive a lower crawl ratio in the Grenadier but that would impact on road driving as this lower gearing would apply when in both high range and low range.
