HVAC
HVAC functionality of your 2024-2025 Grennys
  • A- works well
    Votes: 12 9.4%
  • B- works adequately
    Votes: 43 33.9%
  • C- hit or miss
    Votes: 45 35.4%
  • D- generally poor
    Votes: 23 18.1%
  • E- works adequately /well after multiple dealer visits
    Votes: 4 3.1%
  • Total voters
    127
Hi Tom, did the dealer say how they fixed this for you? Was it a problem with the water pump? Or possibly software related?
Agreed. I had the super-hot rear condition 2-3 times over the Summer of 2024 and it was resolved by the dealer.
I'll need to pul lthe paperwork to see if they noted any details. I also had the drips on the drivers floor mat, so this fix entailed removing most of the dash.
I have a 2023 model Fieldmaster diesel that is going back to the workshop to try to remedy the problem of cold air flowing into the passenger's footwell. Has anyone else had similar problems and, if so, had them resolved?
They have already taken the recommended measures with grounding points and bled the air from the system.
What happens is that cold air flows from behind the glove compartment, and it seems to come directly from outside since it is not heated and the flow varies with the speed. It seems to depend on the fan speed as well – it's worst when the fan is on settings 1 or 2. If you manually increase the fan speed, less cold air comes out. I suspect that there is a flap or a similar component that is not closing properly.
When I drive in auto mode, everything is fine for the first ten minutes. Then the automatic system thinks the car is warmed up and lowers the fan speed. That's when cold air starts coming in (but only on the passenger side). The past week, it has been 4-7 degrees Celsius outside, and if I measure the temperature on some surfaces (seats, door side, etc.) with an IR thermometer, it is about five degrees Celsius colder on the passenger side.
G
Get under the passenger seat and check cabin filter whether there is any obstruction to the recirculating flap opening and closing. You can check by turning on/off the recirculating air button. Possible causes is that a strip of foam may have become detached from the cabin filter. Also open up the cowling outside next to windscreen and check for any debris or obstruction. I would check this first, no joy then dealer.
OK so I had some time to play with the HVAC system while I was waiting to pick someone up, here is the strangeness;
A/C - Doesn't work at all , button, no button doesn't get a little cold at all.
The truck was hot so I turned down the temp to cold but it was still burning coming out of the front vents, once I switches it to defrost the the temp came down and stayed down, even when switching back to face/floor.
There was no heat (or cool) coming out of the rear vents, nothing no matter what I did, so I put on the front demist and boom blowing out the rear vents even when I turned off the demist. WTH
This has to be the biggest pile of garbage HVAC I have ever seen in a car, my 79 911 had better HVAC and it used heat exchangers.
I have a huge list now and am booked for my first service at the end of the month but I am not hoping for much. Ineos should really be going back to Webasto and asking for a new system (retrofit) as HVAC systems have been working fine for over 50 year in vehicles, and this is supposed to be an overland vehicle. It's like it's built with pulley's and strings. Don't get me started on no fan at all at times of extreme cold...
Well i can be added to the list too now :D
Today on my way in to work - 30 minute or so drive - turned the aircon on as it was getting a bit warm - front blew reasonably cold (cold enough as it was only set to 23degC) but the rears were doing their best to melt the plastic.. tryed changing settings etc and nothing worked - so just shut the vents off. Got to work - took a phone call and left it idling - then checked the rear vents again and they were blowing cold again... nothing touched or settings changed... odd...
Hopefully its a software issue or at least a simple fix.. not an issue for me at the moment... but i'm sure it will be eventually if it continues.. .i'll monitor it but its the first time ive noticed it doing this in 4 odd weeks of ownership
10/25 build
  • Sad
Reactions: CRH
In other words, you are driving a MY26? I haven’t heard about HVAC issues on the new models yet.
No its a 10.25 build and MY25 (i would assume one of the last) so old hvac and steering (which I have no problem with!) Ive just been watching the videos on the system and it intrigues me how we can have cold to the front and hot to the rear - ity has to be heater or coolant core being activated the bypass being closed and the front being fed only by the 6.5% bypass channel - when closing the rear vents the air speeds up considerably in the face but i would assume thats just pushing more air through the bypass channel... its certainly odd
Check coolant levels, run bleeding procedure when cold. How many miles on the truck? Keep doing this and driving until it's normal but very slow to respond.
Also check aircon gas levels
I tried opening and closing the recirculation, and the valve works as it should. It moves smoothly and closes completely.
The system works properly at the start of a drive, but after about 10 minutes, cold air begins to enter the passenger footwell. It then becomes about five degrees Celsius colder on the passenger side compared to behind the steering wheel. This has been consistent for all drives in recent weeks.
I will try to stop next time it happens to see the position of the recirculation valve.
G
I'll get the dealer to check when it goes in at some point soon - it strangely was very cold on the home journey but interestingly as the car had sat for 7 hours - the temp gauge rose to 90degC within 500m of leaving work - which is obviously wrong as the oil temp was way lower... seems to just be a bit glitchy... i'll keep an eye on it and see if i can spot a pattern.
In my opinion though seeing how it works from the vids on the other thread - it has to be flaps doing the wrong thing... i dont see any other way the rear can be red hot and the front cold...
Its done 8000k's i got it with just short of 7000k's 4 weeks ago.
Steve
Steve
Mine & lots of others were like that, hot rear and cold front. It's air in the system, weird!
Engine heats up very quickly according to the standard temp gauge
Was yours consistent or intermittent?
Steve
Steve
Both, sorry to be vague but it was.
I hit 30,000 miles around Christmas, it started acting up, I checked the coolant and it was low on one side. Since then it has been working as I would expect. As long as you don't have full on heat until you cook your feet, as i often do, it can't cope with lower temps and just blows cold. I have to put full fan ice cold through the system too cool it down then it will work normally again.
It had been working fairly well until Christmas when it wasn't coping so well and acting more like you described. It had been working fairly well for quite some time. Since then it had been into Ineos and I did mention the heating system just to see if they could improve it. But since my last top up and about 2,000 miles it's working. I checked the levels this morning and the blue cap tank was below max. Just keep an eye on it.
Mine started blowing hot when I was driving to drop it off for 1 year service, luckily the service manager was able to see it blow hot in action.
They sent me an updated and mentioned...
As part of diagnosing the AC concern, we carried out a series of system checks. This included performing a pressure test to verify proper refrigerant levels and confirm there are no leaks or restrictions in the system.
We also performed electrical testing of the AC system, with particular attention to the grounding points. During this process, we tested and cleaned the grounds to ensure proper conductivity, and tightened a connection point to restore a reliable electrical path.
The concern where it felt like the heat was on was due to the AC compressor not consistently engaging. After completing these corrections, we re-tested the system and confirmed that the AC is now operating properly and cooling as expected.
Lucky it happened when it did and 🤞 that it is actually fixed. Last time it was in they fixed the A/C condensation issue. Will update if any additional information is available on the service bill.
Reactions: CRH
This is what Rusnak Ineos in Pasadena did to diagnose and fix A/C blowing hot.
Worries me that they mistake grams for kilograms ( e.g., invoice says "Recovered 480KG of Gas") but this is America! Can you imagine 480 kilograms of refrigerant in the A/C system!
Odd that they don't note pressure readings for high side, low side or vent temp tests before/after.
Says not coolant leaks found. Not sure if they are talking about coolant or refrigerant...in my book those are two different things.
Mentions SSM, which I assume is a Special Service Message? So not a TSB yet but in the system as a SSM. Door Seals feel into the TSB category...hadn't had any issues there, but hopeful glad that they fixed them (replaced them)
