Hey Guys! AJ From GP Factor. Excited to be a part of this forum as a vendor and lifetime member!
If you are unfamiliar with GP Factor, we produce high end vehicle parts and camping gear in the USA. We have prided ourselves on making parts that do not compromise on quality, and provide years of hard use. We had announced earlier this year that we will be making a full line of parts for the Ineos Grenadier. Currently, we produce one of the best folding tables on the market. We are excited to announced and give you all a sneak peek to the version we will be releasing for the Grenadier! This table is currently based on the same proven design we have made for years for Jeeps, Campers, Broncos, and Land Cruisers. It will be sized and specifically designed for the Grenadier. The specs of this table for your Grenadier as follows:
  • NO drilling or modification. This will use the existing factory bolt riv-nut locations so installation is super easy. You could even use your factory mounting hardware.
  • It will come with our patented cableless hinge design that is both durable and easy to use.
  • Table is made from food Grade 304 stainless
  • One handed dual latch design for easy closing and opening
  • All tables include a ½” bamboo cutting board that can be removed for cleaning or flipped over for dual sided use.
  • We will be releasing a second version of this table that will have a compartment built into the backer (like the factory plastic piece)
FULL LISTING FOR THIS TABLE CLICK HERE: GP GRENADIER FOLDING TABLE
We will be opening up preorders for these in a few weeks and plan to ship the first batch in January/Early February 2024. I have also included in this post some pictures of our existing tables for reference.
You can also find a lot more pics, videos, and other media on our existing tables on our Instagram or website - @gp_factor
We will be releasing other products soon (maybe some stuff you all have been requesting…) for the Grenadier so keep an eye on our vendor area of the forum and also subscribe to our email list as well on our website – Gpfactor.com
Thanks and let me know if you have any questions! Cheers,
Jeffrey
4:30 PM
GPFACTOR
Supporting Vendor
7:30 PM
United States
Good Morning All,
Just a heads up if you dont see it in the "Electrical" Section of the forum - Our CTEK D250SE Mounting Plate kit is NOW available for Preorder. Orders will ship in about 2 weeks. Cheers!
If your Grenadier came with the factory dual battery system, then your vehicle is equipped with the CTEK Smartpass. The easiest way to integrate an MPPT Solar controller and improved charging capabilities into your existing system, is to use the CTEK D250SE DC/DC Dual Battery Charger. We have made a mounting plate and connectors that will make this integration seamless and easy for you! The kit includes the following parts and features:
FEATURES:
  • Mounting plate that bolts to under the existing factory CTEK Smartpass. The plate has an offset raised platform for the CTEK D250SE so there is not interference for the wiring coming from the D250SE with your Factory seat brackets and hardware. No Modification needed to install this.
  • Rubber coated leg base to insure no rattling of the mounting bracket against the floor of your Grenadier
  • Pem nuts on the bottom of the bracket for securing the D250SE so you only need one tool to install and no need to mount the D250SE before placing the bracket in the vehicle.
  • X2 copper buss bars that connect the D250SE to your Smartpass perfectly
  • X1 Ground Cable Harness for connecting the D250SE to your AUX battery (See D250SE instructions for how to wiring based on what battery you have)
KIt Includes:
  • X1 ALUM Mounting Bracket with integrated Pem Nuts for mounting D250SE
  • X2 Copper Bussbars for connecting D250SE to smartpass
  • X1 Ground Harness included
Oelprinz
3:30 AM
Dubai - United Arab Emirates
Just in case anyone doesnt see the other thread:
Some good news for you. We are proud to finally launch the Extended Cubby Version of our tailgate table! Here is the link to the website, so I wont bore you all with all of the specs that are standard on all the tables, but here are the key points on this version:
1. Approx 650 cubic inches of storage space
2. Table folded up serves as the door which allowed us to extend the storage area almost 1.5" deeper than the factory plastic area that was borderline unusable.
top of the cubby has molle for mounting whatever you want and a spot for wiring up a national luna 10" LED light or any LED light you want to stick there. Wired or go with a rechargeable one.
Side walls of the cubby have molle cut outs for using a bungie cord to add extra security to your cargo, or for mounting other accessories.
3. Tables are open for preorder now and should ship in about 6 weeks from today.
Do you have more information about the installation of the wired light? I'm really not good with electrics unfortunately, so was hoping you have some explanations for the wiring please :)
Rubicon Maybe
6:30 PM
Brentwood, TN, USA
awesome! Appreciate the support. You guys will all be the first to know when we start getting this out in the mail in the coming week or so.
How is the construction of the upgraded folding table going? Do you have a potential launch date?
Thank you so much for the insight.
GPFACTOR
Supporting Vendor
7:30 PM
United States
So the standard flat backers are in stock and shipping. Cubby version should be back from coating in about a week so we can get those on the move to everyone. Very sorry for the added delays. We had hope to ship about a week ago or earlier this week but got a little delayed.
Rubicon Maybe
6:30 PM
Brentwood, TN, USA
Thank you for the update. Delays are always a part of the equation in manufacturing. Looking forward to their release. Suspect many others will be excited by it also.
Chuck
Oelprinz
3:30 AM
Would you please so kind though and inform us once they’re shipped? Can’t wait to receive it but with the transport over seas, I reckon I got to wait few more days…
Global Grenadier 0076
7:30 PM
I have a mysterious package due in today from York, PA ... could it be? :D
7:30 PM
Not yet... trust me, first thing Ill be doing is posting up to you guys when we start sending out the first ones :) Should be between Friday and next Tuesday.
Hmmmm. I guess I'll be surprised this afternoon.
GPFACTOR
Supporting Vendor
7:30 PM
United States
Good Morning,
CTEK D250SE Kits Preorders Shipped Yesterday and they are in stock for shipping. Update on the kit if you missed it - All kits ship with the Copper Buss Bars that have a 3m Rubberized coating we applied to the copper. Cheers!
Efatl
7:30 PM
Atlanta, GA, USA
Sorry I missed this. Its Approx 3.5"
Hi - I am trying to purchased the Ineos Grenadier Folding Tailgate Table with Extended Storage Cubby using the discount code posted a few weeks ago and it is not working, either in shop or by creating an account on your site online. I have also cleared the cache. Are you able to help?
GPFACTOR
Supporting Vendor
7:30 PM
United States
Thank you so much for the update. Excited to have one of your products going on the IG. Congrats on getting this to market.
Thanks man! Appreciate all the support from the forum. A lot of tables going out today, tomorrow and Friday! All web orders will be out today. Cheers guys
