Mounting a 50” / 40 amp light bar to the roof
shimmy
9:55 AM
Boulder CO
Hi all, not finding anyone who has done this exact set up so curious what folks recommend. I bought a Heretic 50” light bar on Black Friday sale and intended to mount it up on my roof TrailRax roof rack. As I was about to wire up the harness to the dedicated roof plug I realize this is a 40 amp system, and these are 25 amp outlets. I assume the wiring and everything is not suited to handle 40 amps even if I were to replace the fuse (unless I’m mistaken?)
So now I’m trying to figure out how to wire this thing up. I have a harness with everything needed and can expand lengths if i have to. But it will likely have to come in through the roof to a fixed wire setup. Does anyone have examples of doing this? Looks like I will go in through the stock holes where the existing wiring is, underneath the seatbelt trim, and underneath the rear seats to the electrical panel. Are there stock hard mounting points or a bus bar? For the switch… not sure. Would love to reuse a stock switch somehow. The included switch is lame but can use if needed.
Any help appreciated!
Edit: Also for the record willing to just find a light bar in the 25A range for that plug if the juice isn’t worth the squeeze. I prefer low hassle/“stock-ish” setups. Curious what others think.
Correct wiring will not safely handle 40 amps.
The aux fuse box may not be rated to handle that on the circuit as well.
The easiet option is to buy a lightbar rated at 25 amps or below and change the plug to a DTP and just plug it in, like the INEOS lightbar does.
I started taking things apart and believe I can hard wire it directly into the electronics compartment. Would it be appropriate to connect the hot wire to fuse box supply (pictured)? Wondering if it’s possible to reuse one of the EXT switches for the relay…
Confirmed the light uses ~35 amps when running (using the built in Off-road/Electronics menu).
I would take the power supply from one of the connections in the busbar that I have circled in red.
Then I would run a wire from one of the INT outputs to the relay you are going to use. Not too difficult if it is INT1 or 2, you can just tuck the wires behind the trim or under the carpet.
If you are feeling adventurous you could drop down the overhead panel and take an output directly from one of the auxiliary switches (to turn the lightbar relay on/off) and feed the wire across the headlining and down the B pillar. That would be a longer job.
For the bus bar I didn’t go in there since it’s already full, but I can piggy back off of any of the posts in there if it’s all the same.
For the switch using one of the INT aux switches will work perfectly since I don’t have a use for them anyway. Great suggestion!
The harness that came with the light includes a relay and a switch both with three posts. I assume one of the posts is for the red LED, the other is a hot to the relay and the other is a ground? Can I simply reuse the relay’s switch leads to close the circuit with the INT wires?
It looks like the supplied switch is getting the 12v from the battery (red) and feeding 12v to the relay (blue) when the switch is closed.
Since the INT switch already has a 12v supply you don't need the red wire.
Connect the + from the INT to the blue connector and the - from the INT to the black connector.
A little late to the party, but a fair number of people report light bars in the position you show (for any 4WD vehicle) end up illuminating the engine hood with an obnoxious glare. Lights halfway back on the roof can use the roof to cast a shadow on the hood, or mount the lights elsewhere, like the bumper, grill or on a bull bar.
Yes I could definitely see that - with this rack I have the option of moving it "back" to a 3/4 rack and putting the light there. I wonder if then it would blast in the safari windows. Will report back to see if this is an issue or not. May also be addressable with a dark hood decal which I was already considering.
Also late to the party, but what about using the factory 25amp switch to switch the relay rather than the switch that came with the harness?
Its not so bad. Ive got a STEDI 52" ST4K which effectively turns night into day mounted right at the edge of my roofline off the bottom of my Frontrunner Roofrack.
Yes, there is a noticeable illumination of the hood of the truck, no it is not a glare, or distracting in any way.
It sure does lightup the darkest of darks.
If your camera viewpoint matches your eyeballs, your seat height hides almost all of the hood. Having a high ceiling in the cabin and a big range of seat heights is nice.
If you’re referring to my pic there, yeah I have the seat all the way back and all the way down.
I’m 6’ and 220 lbs
I’m sure this particular situation has resolved, but I wanted to add relevant material here for organization sake. I’m running a Baja Designs 50” S8 light bar off my full length roof rack pulling approximately 21A on my 25A prewired switch. The center sections are spots focusing the light pretty far out in the distance, and the side sections have mare of a left to right flood effect. I don’t have any hood glare issues, but I also added a satin/matte black hood PPF material since I wasn’t sure if it would be an issue.
Iam looking at refining this as its the way our blacksheep lightbar is wired (roof outlet via "EXT3"),
I hope to have it piggyback a signal from the overhead "aux headlight" switch so i can dip it in conjunction withthe headlights to as firstly not to blind other drivers and secondly to actually conform with the Au ADR Rules if challenged.
I believe it is tapped from the high beam circuit?
8 - Aux High Beam Headlights,
-Press switch to switch on. Car must be running.
-Lights will activate when high beam is selected. In addition, NAS vehicles also need offroad or
-wading mode activated.
-Press switch again to switch lights off.
Iam assuming this is the switch in question?
If so I imagine I could take the supply side of the EXT3 relay control switch and feed it from the "D_SW" signal?
BTW on the MY24 Au quartermaster the passenger side roof outlet is EXT2 and the drivers side EXT3, as there are no other roof outlets mike on the Wagon they simply have a single outlet on ea CCT.
so far i havent found the EXT2 or # switches in the wiring diagram,
My Viper LED lightbar was done this way, in accordance with the ADR, I think he used the signal from the spot lights, but I was not allowed in the workshop to see exactly:
secret mens buisness hey doc!
sheesh talk about petty when you can just drop the roof panel and it will be obvious what they done!
anyway you can add this you your grenny bible next revision re the outlets on the quartermaster,
I was allowed in the workshop for some time, but not when that work was being done.
I worked out how to fit the lightbar and they allowed me to do it. There was a few fiddly bits and getting the bolts around the right way so it fitted onto the roo bar.
Interesting That's the opposite way round to the Wagon which has the drivers side roof outlet on EXT2 and the LHS side and rear ones on EXT3
Cheers
Steve
