Hey Guys! AJ From GP Factor. Excited to be a part of this forum as a vendor and lifetime member!
If you are unfamiliar with GP Factor, we produce high end vehicle parts and camping gear in the USA. We have prided ourselves on making parts that do not compromise on quality, and provide years of hard use. We had announced earlier this year that we will be making a full line of parts for the Ineos Grenadier. Currently, we produce one of the best folding tables on the market. We are excited to announced and give you all a sneak peek to the version we will be releasing for the Grenadier! This table is currently based on the same proven design we have made for years for Jeeps, Campers, Broncos, and Land Cruisers. It will be sized and specifically designed for the Grenadier. The specs of this table for your Grenadier as follows:
  • NO drilling or modification. This will use the existing factory bolt riv-nut locations so installation is super easy. You could even use your factory mounting hardware.
  • It will come with our patented cableless hinge design that is both durable and easy to use.
  • Table is made from food Grade 304 stainless
  • One handed dual latch design for easy closing and opening
  • All tables include a ½” bamboo cutting board that can be removed for cleaning or flipped over for dual sided use.
  • We will be releasing a second version of this table that will have a compartment built into the backer (like the factory plastic piece)
FULL LISTING FOR THIS TABLE CLICK HERE: GP GRENADIER FOLDING TABLE
We will be opening up preorders for these in a few weeks and plan to ship the first batch in January/Early February 2024. I have also included in this post some pictures of our existing tables for reference.
You can also find a lot more pics, videos, and other media on our existing tables on our Instagram or website - @gp_factor
We will be releasing other products soon (maybe some stuff you all have been requesting…) for the Grenadier so keep an eye on our vendor area of the forum and also subscribe to our email list as well on our website – Gpfactor.com
Thanks and let me know if you have any questions! Cheers,
Andiamo
12:31 PM
USA
What’s the timeframe for the rear table availability? Canceled my factory order and will order your version as soon as it’s released!
GPFACTOR
Supporting Vendor
12:31 PM
United States
We should have the first version release soon here, with it shipping about 6 weeks after. The second version will follow about a month behind
[ Adam ]
12:31 PM
Fairfax, VA, USA
New Products released today from us:
Ordered the maxtrax bracket. Looking forward to a ladder scepter mount.
Andiamo
12:31 PM
USA
Do you have any pics or diagram of what the table with the storage cubby will look like?
GPFACTOR
Supporting Vendor
12:31 PM
United States
Good Morning Grenadier Fam!
We are excited to announce our Folding Tailgate Table is now available for the Grenadier. Full Info below and click the links to learn more.
*Pre-orders are now open for the first batch! You can place your order GPFACTOR.COM or at OK4WD.COM. Pre-orders placed between 1/26/24 & 2/29/24 will all ship the around the end of Feb in 5-6 weeks.*
DESIGN
The GP Factor Ineos Grenadier Folding Tailgate Table incorporates GP’s patented table and hinge design. This hinge is completely cable-less and can handle weights beyond what is needed for a drop table. The table hinges utilize a two latch system that allows users to release and latch the table one handed.
TABLE SURFACE
The GP Factor Ineos Grenadier Folding Tailgate Table surface is made from #4 food grade stainless. The mounting backer is made from durable aluminum with a clean, textured powder coat black finish. The rest of the hardware is either stainless steel, or black nitride for added durability and corrosion resistance.
CUTTING BOARD
All GP Factor Ineos Grenadier Folding Tailgate Tables come equipped with a huge 23.5” x 14” bamboo cutting board that stores blow the table surface. This cutting board can be removed for cleaning or use off the table as well.
INSTALLATION NOTES
One of the best parts of this table and the Grenadier is there is NO Modification needed to install or run this table. The table will bolt to the existing tailgate Rivnut locations with the factory hardware or the stainless we will provide with the table. Installation will take less than 15 min! Simply remove the factory plastic panel, and put on our table!
FEATURES AND BENEFITS
  • Food-grade 24x14" stainless table surface
  • Proprietary reinforced stainless steel hinge design for long term durability and ease of use. No more stretched cables getting in the way. Weight capacity rated at 60 lbs
  • Custom 24"”x14” bamboo cutting board can slide out to left or right side of table to meet the user’s needs
  • Micro two-stage rotary latch system allows users to release and close table with one hand
  • Lightweight aluminum back panel with durable Grey Anthracite textured powder coat finish
SPECIFICATIONS
  • Back Panel: Aluminum with Anthracite Grey textured powder coat finish
  • Table: 304-#4 food-grade stainless steel
  • Hinges: 304-2b stainless steel
  • Pat. Pend. Hinge Nut: 4140 steel with Blacknitride+ (Salt bath ferritic nitrocarburizing) finish
  • Hardware: Stainless steel
  • Cutting Board: CNC cut bamboo
  • Dimensions of table surface: 24” x 14”
  • Weight Capacity - 55lbs
  • Weight: Approx. 21 lbs
  • All GP Factor Ineos Grenadier Folding Tailgate Tables are 100% Made in the USA
carlg007
12:31 PM
Florida
DESIGN
TABLE SURFACE
CUTTING BOARD
INSTALLATION NOTES
SPECIFICATIONS
Great design and much nicer than the Ineos option!
pauldulin
12:31 PM
Florida, USA
DESIGN
TABLE SURFACE
CUTTING BOARD
INSTALLATION NOTES
SPECIFICATIONS
Do you still expect to make a version with storage cubby? I'm definitely interested but may wait for the next iteration if it has the cubby....looks awesome!
DaBull
9:31 AM
California
DESIGN
TABLE SURFACE
CUTTING BOARD
INSTALLATION NOTES
SPECIFICATIONS
Hi GPFACTOR, I like the design. Are you also considering a version where access to the plastic panel holding the safety gear will be accessible?
DaBull
carlg007
12:31 PM
Florida
DaBull
I think I read somewhere that they thought about that but did not think it was worth the effort for such a small storage space. I could be wrong!
GPFACTOR
Supporting Vendor
12:31 PM
United States
DaBull
This is just the standard version with flat backer we launched today. We will have another version coming very soon that has a built in cubby that’s a little larger than the factory version. 👍
GPFACTOR
Supporting Vendor
12:31 PM
United States
Just in case anyone doesnt see the other thread:
Some good news for you. We are proud to finally launch the Extended Cubby Version of our tailgate table! Here is the link to the website, so I wont bore you all with all of the specs that are standard on all the tables, but here are the key points on this version:
1. Approx 650 cubic inches of storage space
2. Table folded up serves as the door which allowed us to extend the storage area almost 1.5" deeper than the factory plastic area that was borderline unusable.
top of the cubby has molle for mounting whatever you want and a spot for wiring up a national luna 10" LED light or any LED light you want to stick there. Wired or go with a rechargeable one.
Side walls of the cubby have molle cut outs for using a bungie cord to add extra security to your cargo, or for mounting other accessories.
3. Tables are open for preorder now and should ship in about 6 weeks from today.
Tom109
12:31 PM
How deep is the storage cubby overall?
Jeffrey
9:31 AM
Beautiful piece of design and work. I'm still trying to swallow this and determine just how much I need this. Might there be a forum discount and free shipping?
DaBull
9:31 AM
California
Hi Jeffrey, I just used this discount code that AJ Lafferty sent me. It is for 10% off for Grenadier Forum Members.
10% off Discount Code for Forum Members IGFORUMFAM10
I just ordered the new GP Factor Ineos Grenadier Folding Tailgate Table with Extended Storage Cubby a few min. ago. It is a beautiful design and bit of kit for my Grenadier when I take delivery in a couple weeks.
Here's the link to it:
I also purchased their shovel that is not only two tools, it breaks apart for easy storage.
I will be using if for digging myself out of trouble.
Wonder if it will help dig me out to trouble with my wife when she see's another purchase for the Grenadier.
Here's the link, (not for my wife, the shovel).
DaBull
