Front Drive Shaft Update
Just wanted to throw this out there and see what y'all are thinking: since I really only need four by four when I am going off road, could I just remove the front drive shaft, keep the center diff locked and attach it when I am going out on a off-road trip?
You will cause significant wear to your transfer case and potentially cause failure of your rear differential. I stress potentially as the diff should be more than fine, but you are adding a lot of extra stress and I am not sure yet how robust these axle truly are.
Yeah speaking with my maintenance manager yesterday the Ineos protocol now is to remove (or change) the O-ring from the breather to ensure pressure equalization.
Probably just worth it to add an extended breather kit.
I picked up my truck today, and had the details wrong, They Added an O-Ring, not removed, and cleaned up the breathers to allow for pressure equalization. Hopefully it helps, and stays clean.
Coming in hot off of Facebook. Drive shaft broke for guys as they are in line to board a ferry. . Back on road in 22 hours.
A much better story than Cannygate.
It sounds like Justin Hocevar himself did the run to the ferry port at Geelong to drop off the driveshaft. There wouldn't be too many recognisable 'big dogs' called Justin working at IA HQ in Melbourne 👏
Planning a 3 week trip to the Kimberley’s mid year, quite remote… which vehicle should I take…🤔
Leaning towards my 30 year old Defender…
If this is Justin Hocevar then I'm mightily impressed...what a great attitude. From what I've seen of Justin in the media, he comes across as a no-nonsense, customer focussed, get the job done sort of guy. Refreshing to see this in any business these days.
Their propshaft has had some use ( see quote); he probably should haved checked it before the trip. Btw , Tassie weather over the next week is pretty ordinary, but I'll take that over 35-40C that will strip the skin of the mainlanders!
" we have done 73,000km of driving in the last year all around Australia doing some of the worst roads there are. I have put it down to bad luck and heavy relentless use"
I’m also planning to spend a month in the Kimberley from late July next year. I’ll get an intermediate service completed before I leave Perth which will include a good check over underneath. As my car is totally standard suspension and wheel wise, I’m not expecting any major dramas plus I’ll be travelling with friends so if anything goes pear-shaped, I’ll have support.
Cheers
Steve
How many spares would you need to carry for an old Landrover compared to a Grenadier.
Old car more simple to repair anyway, new car more comfortable especially with aircon.
Is the old vehicle more likely to break as it's old, no matter how well you service, unless it's a nut and bolt rebuild with all new parts, it's still old.
I'm not defending one or the other, just asking the question.
It’s normally the spares you don’t take that you’ll need. Some materials for a bush fix is what I take. Plus some spare fluids, filters , brake pads etc.
