Front Drive Shaft Update
100% gets pinched. The rubber gets extruded by the pressure and thins out. Eventually it develops a tear which centrifugal force takes advantage of and finishes the boot off.
This happens on stock or lifted trucks. Just happens faster on lifted because you live closer to the extrusion point.
Pinching of the boot is a serious design flaw by Ineos/Dana/Magna and should have been easily identified during development. An engineering 101 screw up of the highest order. Excessive flexing of the boot while also unacceptable at least would have been less easy to identify as an problem. Dana or Magna had to raise this as an issue and Ineos chose to do nothing and proceed with production anyway.
Dana is not responsible. Ineos along with Carraro did not set pinion right for the drive shaft angles. Tipping the pinion up a few degrees would have solved the problem. Reducing your stock shock length by 1" would also solve the problem, but reduce off-road performance a bit of course.
Ineos could literally back out of this by doing a shock recall to reduce max travel and 99% of owners wouldn't know any better.
And those with super low caster numbers may never have a problem with the drive shaft, but they are accepting the poor steering characteristics.
Regardless of who should be blamed it is a problem that should have been easily identified during the development process. One million miles of road/trail testing without a single CV boot failure. Not buying it.
And yes the pinion angle is the source of the problem. It should be higher so that it points more directly at the transfer case thereby reducing the CV angle on both ends. At the same time the knuckles should be rotated back/down to increase caster. This will almost certainly be done as a running change, but this will do nothing for existing owners other than to reduce our resale values.
I seriously doubt we’ll ever really determine the actual culprit. I’ll just chalk it up to production time lines and cash.
Reactions: CRH
So would this put it roughly were the front end on 90's RRC's and D1's sat? Not a bad compromise with lockers? 🤷‍♂️
Maybe if you account for Rover radius arms.
The Grenadier doesn't really flex that great. It's ok, but nothing to write home about. So any reduction will be felt. An H strap could solve the issue without limiting articulation but that gets a little messy.
But considering the average use case of the Grenadier a little reduction in travel assuming you have lockers won't be devastating in any way.
I don't think it's as simple as rotating the diff. The output shafts need to run on parallel planes to prevent accelerated wear of the joints.
The same is true of PTO shafts on tractors and implements.
Tom
Well warranty denied. This issue Ineos is choosing the bury the heads approach like other car makers unfortunately. I hate to say it, its a safety issue and it may be time to start NTSB complaints. I know other dealers would have warrantied it potentially, but here we are. And even if it is warrantied, it will fail again. A recall is required and a new design.
I see your signature - so you are not at stock suspension. How much lift? Factory shocks or aftermarket?
Mine has just sheared off at the transfer case. 5hrs away from home just south of Humber bridge. Middle of nowhere. 2 dogs amd me very pissed off indeed. What tools do you need and the procedure to remove the shaft from front diff??
on top of the NTSB complaints, if they continue ignore the issue, I think will just have to continue raising alarms on this forum and others. Just need to hit them through reputation and financial hits. Perhaps they won't care, but they definitely should...
- Ratchet wrench
- Various extensions to reach at least 30 cm
- Long T45 Torx bit
- Torque wrench
- A lever to remove the CV joint on the gearbox side (in my case the first time was very challenging)
Hope there's no one nearby to hear you the first time ☠️
Go underneath and start unscrewing the screws.
If you're on the road, once you've removed all the reachable ones, move the vehicle a few centimeters to rotate the shaft and reach the others.
If you're at home without a lift, lift two wheels and rotate the shaft by hand from underneath.
- Ratchet wrench
- Long T45 Torx bit
- Torque wrench
Tks Orso. If it's sheared off cleanly at the transfer case then can I just leave whats left on that and remove the driveshaft from the front axle?
