I'm curious to know what the official Ineos tightening torque is
- Propshaft bolts are listed as single-use. Propshaft Fixing Kit PN GRA-5D00-019750.
- Removal of the front propshaft calls for remove for access of the transfer case crossmember.
- Each bolt is torqued to 25Nm then turned through (thru!) a further 40 degrees to achieve the final torque.
- No mention of the tabs that are installed under adjacent bolt pairs as shown in the screenshot.
- No callout for a tightening sequence.
Remove
- Install a Brake Pedal Depressor. Refer To: Brake Pedal Depressor (Remove for Access and Install)
- Remove the Transfer Box Crossmember. Refer To: Transfer Box Crossmember (Remove for Access and Install)
- WARNING: Powered Tools should not be used during this procedure. Failure to adhere to this warning could cause damage to tools and components.
- Remove the eight bolts that attach the Propshaft to the Transfer Box.
- Remove the eight bolts that attach the Propshaft to the Pinion Flange.
- WARNING: The Propshaft is large and heavy. The aid of another technician is necessary for this step to make sure that the Propshaft does not fall. If you do not, this can cause serious injury and/or damage to the vehicle and equipment.
- Remove the Propshaft.
- CAUTION: Make sure that you install the Propshaft in the position shown. If you do not, damage to components can occur (see screenshot).
- Move the Propshaft into position.
- Install and torque the eight new bolts that attach the Propshaft to the Pinion Flange to 25 Nm.
- Torque the eight bolts that attach the Propshaft to the Pinion Flange thru 40 Degrees more.
- Install and torque the eight new bolts that attach the Propshaft to the Transfer Box to 25 Nm.
- Torque the eight bolts that attach the Propshaft to the Transfer Box thru 40 Degrees more.
- Install the Transfer Box Crossmember. Refer To: Transfer Box Crossmember (Remove for Access and Install)
- Remove the Brake Pedal Depressor. Refer To: Brake Pedal Depressor (Remove for Access and Install)
