Front Drive Shaft Update
These Teraflex joints are better priced on Amazon.
UK - £159 Amazon vs £220 from Jeepey.
This ist the wrong kit. It is for a Jeep JK. We need a kit for a Jeep JL/JT with the number 1745000.
  • Jeep JL:png.png
    Jeep JL:png.png
Curious how much long distance driving you have done. Drives in excess of 1hr one way.
I live in a pretty remote area. It takes me an hour and twenty minutes to get to Costco which I do about once a month. I did a 3500 mile road trip last fall (with the lift). I have done multiple trips to Portland and Seattle which can be 1.5-2.5 hours depending on traffic. I have driven the entire Olympic Peninsula in a day multiple times. I wish I could make sense of it. I carry TeraFlex spares and will keep checking.
I saw that but wasn't sure it would arrive before I leave for Montenegro so I got the other one... Should have been better organised!
Nice, sounds like you are putting it to use. I hope it continues to hold up. My Terraflex has been holding strong so far.
Derek in northern CA has it on his. I think @derek0343 is his username. (We have a local WhatsApp group). He has several thousand miles on it and is very happy with the driveshaft from agile.
I'm thinking about doing both front and rear as a just in case.
I had a driveshaft disaster today.. The Terraflex cv that I ordered as a spare for my upcoming trip hadn't arrived, I checked my messages and emails and found nothing so I went back to the original email and found a tracking number... Turns out that DPD delivered it last Saturday.... to my wheelie bin... which was emptied on monday....
So now I'll have to see what Jeepey's customer service is like.. and whether they can replace it before I leave next weekend..
I'm not aware of any rear ones letting go either.
If you wanted the whole trailerfull of spares you'd pack the entire driveshaft . "Just in case".
Can't see the Ineos techs greasing the unis or slip joint at a service, not on the service sheet. It will be something the owners will have to keep on top of.
Yes , all you Chelsea tractor mall crawling owners out there better get some dirt under your nails!
@derek0343 Sorry probably a stupid question but what does the sway bar air link do instead of a disconnect? How does it work?
I believe the concept is the same except you never have to disconnect it. Instead there’s a shock absorber in the middle of the sway bar that will expand and contract as needed off road allowing the gain in articulation.
This is what I’m going to do I think. Heading up to the cape for our annual fishing trip ant the end of September and, while heavy, easier to just take a spare shaft I reckon.
If you haven't changed the joint to a non sealed version then you are correct. But once you have changed the joints once then it's super easy to just swap joints real quick.
