Front Drive Shaft Update
Your caster is set almost to the lowest amount in that pic. Will be interesting to see how it feels to you.
I am taking into a shop two weeks after pick up to get Radflo suspension added. I'll have the before and after report to share.
From the front motor mounts to the tarns/t-case mounts is a bit of a distance. I kind of agree that it would take several inches of shimming to appreciably change the front output angle. At that point we may be running out of room under the bonnet or under the floor. A cut and turn would probably get you a better angle at the transfer anyway despite the cost.
I'm just proposing an alternative to the cut and turn
Certainly pinched is an issue. But only when servicing the front end without shocks on it or if you run dramatically longer travel shocks.
No Load on axel or are you saying no shocks on it?
No shocks. To easily change the springs on the front you have to remove the shocks so you can get enough room to install springs. Doing this without removing the drive shaft can lead to pinching the CV boot. But with the shocks on you do not get enough travel to max out the CV's boot assembly.
You get the same result if you run shocks with more extension. Or extend the existing mounts to increase droop.
Thanks, having new Radflo shocks added on 4/23. I will make sure they do one side at a time or disconnect the shaft
Changing shocks out is generally not an issue. They should not drop the axle much if any.
But people should be cautious about shops using two post lifts on their trucks and working on suspension.
AO dropped there new front drive shaft, with dual u-joints. I was looking at
Heavy Duty Front Drive Shaft for INEOS Grenadier by Agile Offroad​
$1,449.99
That's a lot of money for a pretty basic shaft. Especially when the joint angles exceed the continuous operating limit of the joints. Will be interesting to see how people respond to this shaft once in use. My front shaft with the lift is sitting at 13° on the front joint and about 15° on the t-case side. At about that angle you will start feeling vibes from a Ujoint shaft at highway speeds when you transition on and off the power. This is why Tom Woods wouldn't make a shaft.
The continuous operating angle of a 1350 U-joint is typically:
  • 3 degrees or less for long-term, high-speed operation (to avoid vibration and wear)
  • Up to about 7 degrees for short-term or low-speed use
In practice these angles are exceeded all the time with varying degrees of success. But, when shafts fail it causes an awful mess and in the case of the front shaft it can even take out the transmission case. My buddy had one fail on his D90 at highway speeds and it came up through the passenger floor board 😮.
I'm learning here, are you saying due to the angle being greater than 3 and 7 degrees for permeant use (bc I'm lifted) the angle will cause the oem drive shaft to fail? Or this design will fail due to that?
In Europe they have another option now with Sven, there is post on forum about now.
"New specific transmission shaft Grenadier, planned for a 2.5-3 inches increase, double UJ box side and CV joint in addition 15 degrees, no harmonic vibration, mounting with specific tulip bridge side."
I saw that last week on a FB group. The u-joints are 1310's. I'm not so sure that they are big enough but time will tell. It is an interesting approach. Any idea what the price is going to be?
The path that I really wish someone would go down is designing or finding a better high speed Rzeppa boot. It isn't the joint that mechanically fails but rather the boot rips and spills the grease and then the joint fails from lack of lubrication or contamination or both. Here is a boot that certainly appears to be able to handle a more acute angle than the factory one.
I agree, the metal fitting could also be improved along with larger flange, currently they look like they are stamped when I looked the Terraflex CV, rubber material is another area they could improve as you said.
Ugh, I lost a long explanation of this and don't have the energy to retype. But, your stock Rzeppa shaft is good until the grease boot fails. The 3° deal is in regards to the proposed design from Agile. Their shaft simply exceeds the continuous operating limit by a fair bit. Not saying it won't work, it may or may not cause vibrations and may or may not fail in 20k miles or less. But your boot MAY fail in the same time frame. The new aftermarket Terra joints have been reliable so far with only one public report of a boot failure.
