Yes. A DC is two u-joints with a centering ball. What about two Rzeppa's with a centering stud?As in 2 Rzeppas?
Certainly possible, just not a mainstream product. There are some crazy high end joints that can work at insane angles. But they are often to delicate or simply impractical for our purposes.Yes. A DC is two u-joints with a centering ball. What about two Rzeppa's with a centering stud?
How funny is that… that’s me, Ron Johnson, asking the question. I knew I read that they were 1310 u joints somewhere!
Actually, doubling the Rotoflexes is not a bad idea, for a Land Rover. Very simple to implement, too.Or just LR's Rotoflex at the t-case.
I get what you’re saying. It’s difficult to give positives about a prop shaft as there’s nothing to say if doesn’t fail I suppose.As I'm prone to say, 10 positives are required to quell a negative.
Every system/ part failure is blown up on social media and forums to the point where the brand is distrusted.
At what point does the brand step in to address this potential loss of sales or brand exit?
Send me the link please . Isn’t it crazy though that we feel the need to buying such things on a new vehicle !
Yes it is. It was the secondary damage to the transmission and TC plumbing that prompted me to start talking about it, like your experience. @landmannnn has found an off-the-shelf solutionSend me the link please . Isn’t it crazy though that we feel the need to buying such things on a new vehicle !
It did need quite a bit of modification to fit, and the imperial bolts need replacing with metric.Yes it is. It was the secondary damage to the transmission and TC plumbing that prompted me to start talking about it, like your experience. @landmannnn has found an off-the-shelf solution
If the loop does it's job the only secondary damage should be to your Calvin Kleins.
Is there a link somewhere where I can pick those up in the UKIt did need quite a bit of modification to fit, and the imperial bolts need replacing with metric.
(I do have Imperial and Whitworth tools but dont want a vehicle with a mixture)
Amazon - type inIs there a link somewhere where I can pick those up in the UK
Perfect thank you. I will just bolt on some angle iron to the loop to achieve the same affect instead of welding.Amazon - type in
Driveshaft safety loop
They look like this
Basically the process is to take the right arm out of the equation and weld some angle on the left side to pick up the 2x M10 bolt holes in the gearbox cross member.
You could do it with nuts and bolts so a welder is optional.
This is what I did. With retrospect I should have just used the bottom loop rather than what I did here.
The other bracket retains the Bowden cable for the T box as I saw it rubbing, optional extra!
Does that include postage to AU?Perfect thank you. I will just bolt on some angle iron to the loop to achieve the same affect instead of welding.
