Front drive shaft broken
There's a video on YT where a fabricator discusses this, but it was really costly (tens of thousands) as I recall.
In the rock crawling world, and heck, even when people put big lifts on their old jeeps, this is a common thing. But mostly it's shade-tree mechanics and low speed operation.
Also worth mentioning, my 2001 Grand Cherokee came with a double cardan on both ends of the front drive shaft (AWD) and I went 185k on a "lifetime" set of joints. Only developed a little shimmy on downhill throttle off at 75 MPH near when I sold it. For that matter. My 1965 Cadillac El Dorado also had a DC at each end of its 6 foot shaft and it was smooth as silk as well.
I suspect that, if everyone pays close attention to all the driveshaft discussions from the experts, that there is no "perfect" solution for our front drive shafts, but there is the expensive DC at both end "best" solution that nobody wants to build.
Mt prediction: In 10 years we will all have one.
DC at both ends has been built for Grenadiers by multiple people. They have all suffered significant vibration.
Cut and Turn of axle is difficult due to the design of the Carraro axle. Not impossible, but difficult beyond Dana axles or the like.
They really made the Grenadier difficult at best to work with.
Two double cardan joints effectively shorten the drive shaft considerably which makes the angles even worse. So not surprising that vibration was the result. Has there been confirmed use of a custom shaft with a Rezeppa at the pinion and a 1310 double cardan at the transfer case (I don't recall having seen one, only that it has been discussed)? The angle will be pushing the limits for the double cardan and the use of this one DC will shorten the shaft too, but it stands a greater chance of operating without vibration than the twin double cardan setup. The centering ball would need to be lubricated regularly and likely need to be replaced on a consistent schedule, but it might last longer than the OEM Rezeppa at the transfer case. The high operating angle will limit the life of the u-joints too, but at this point it is a question of finding the best compromise out of all the imperfect options. I would be completely fine with rebuilding the double cardan every 20K miles if that was the expected service life without it causing trouble. This is a materially longer interval than many are getting out of the Rezeppa joint.
This has not been done.....yet 😉.
Everyone is hung up on 1350's. Sven may have done it but I don't believe they have the ability to balance the shaft. I may or may not have found a facility that is capable.
I do like the DC at the t-case. Not a fan of replacing the centering ball, PITA factor. If it has the same replacement interval of the CV, I’ll just keep spare CV shaft on hand and casually swap them.
DC center ball will last vastly longer than the Rzeppa rubber boot. But, the angles are still too high for a DC joint if the truck is lifted too much. So the center ball life span may be a bit shorter than normal. But you should still expect 100k miles between rebuilds.
Most owners would likely be happy with a 50K rebuild interval, 100K would be outstanding. I have a local drive line shop that rebuilds the double cardans on the drive shafts from my Jeep. They make short work of it and the price is very reasonable at ~$350 for new u-joints, new centering ball and a rebalance. The Grenadier would just get added to the rotation. This same shop also builds custom shafts. I should inquire as to whether they could balance a Rzeppa/Double Cardan combo.
Post in thread 'Sven Made Driveshafts'
https://www.theineosforum.com/threads/sven-made-driveshafts.12417026/post-1333338093
I’m not sure whatever became of this project. I had high hopes for it.
Yep, that's it. It appears to be a Frankenstein. And I can't tell but I think that might be 1350 joint not 1310.
I kinda recall reading somewhere that it was 1310’s but they do look larger. I wonder what the outcome was? You would think that if it worked than we would have heard more about it.
