- Local time
- 9:48 PM
- Joined
- Jul 27, 2022
- Messages
- 6,005
I don't understand why lateral movement is required, the way I've seen it demonstrated it's a radial motion with a side load from the pins that makes the locking ring engage.I have a small tractor with the same system. You need some lateral movement to line up the holes, i.e. steering input.
View: https://youtu.be/nT_H6rpd-Ck
What you are describing is what I've read previously but seems a pretty odd/redundant way of doing things. Wouldn't it be more accurate to monitor the lock up ring movement into the housing to confirm full lock has been achieved.The issue with the Gren is that rather than illuminate the ’locked’ indicator light the moment the diff is energised it flashes to say ‘energised’ but then goes solid once the diff is engaged. However it doesn‘t monitor actual diff engagement but instead uses the wheel rotation monitoring that is part of the ABS system. If it detects that the wheels are rotating at the same rate it assumes that the diff is engaged. This will take a small distance to achieve.
Does it actually help the diff engage or rather just help the poor feedback required to tell you that it's engaged? Within a few feet of it starting to flash it should be engaged, irrespective of what the light tells you.So for those of you experiencing problems, I suggest trying this: Engage the centre and rear diff, then drive whilst steering from side to side, this will help the diff to engage.
