Bison Gear - 4x4 & Overlanding Accessories
We're Bison Gear, and our mission is to provide you with the absolute best gear for your next thrilling journey. 🏞
Currently, our focus is on the remarkable INEOS Grenadier, recognized as the ultimate platform for overlanders.
First top-notch products are already out in the market, specially designed to enhance your INEOS experience.
But that's just the beginning! 🚀 Soon, we'll be rolling out an entire range of premium gear, meticulously crafted for your INEOS Grenadier.
Stay ahead of the adventure game with Bison Gear – where quality meets exploration! 🏕🔧
The part numbers for replacement headliner hole covers are as follows. I drilled mine and ordered spares so if I remove the basket the spares without holes can be installed.
GRA-7E12-008280 Partition Hole Cover Qty 2
GRA-7E11-040192 Slotted Cover RH Qty 1
GRA-7E11-040181 Slotted Cover LH Qty 1
For any Brits looking at ordering the hole covers here are the prices I've been quoted by my dealer. Now on order, so hopefully in before Christmas.
  • GRA-7E12-008280 Partition Hole Cover Qty 2 - £15.22 + VAT each – Available to Order
  • GRA-7E11-040192 Slotted Cover RH Qty 1 - £11.42 + VAT – Available to Order
  • GRA-7E11-040181 Slotted Cover LH Qty 1 - £11.68 + VAT – Available to Order
A schoolboy error here (again) these parts are the same as those already in the trial/fieldmaster. If you want the ones that are in the station wagon and don't require drilling these are shown below with UK prices (ex VAT) as of today:
I wanted give an assessment and product review of our Bison Gear Ineos Grenadier Roof Shelf after the initial shipping mix-up we experienced. Eventually we came to an understanding and both parties (BG and us) are comfortable with the outcome. We want to commend Bison Gear for staying in close contact until everything was resolved. Thank you as well to the forum members who intervened on our behalf.
As for the Roof Shelf and the associated Under the Shelf Compartment: We couldn't be happier! Both items arrived very well packed and free of any manufacturing grease or residue. There was no missing hardware. Everything appears very well made.
On our Grenadier the second row seats are reclined with aftermarket brackets so we had to make some adjustments to the shelf's installation. While the side mounts installed as usual, it became necessary to shift the shelf as far rearward as possible. This cantilevered the rear edge of the shelf slightly beyond the side brackets. By utilizing the single existing hole at the forward edge of the shelf on each side, there are still three bolts attaching the side brackets to the shelf itself.
While there is no loss of strength per se, I would assume that this arrangement voids the Bison Gear warranty. We use the shelf to carry a set of traction boards (ActionTrax X 4 in carrying case) in an unobtrusive manner. With the weight moved as far forward as possible and centered directly over the side brackets we are unconcerned. A side note here: It appears that Bison Gear has updated the weight carrying capacity of the shelf since our original purchase. I do not advise using it as we have. We will be moving the fire extinguisher to reduce the load on the shelf and to make it more accessible to shorter individuals. I may add structural support to the rear edge of the shelf to prevent any bending or deformation over the long term. We do not intent to carry any other heavy items on the shelf beyond a tarp or possibly a kinetic or tow rope. Any shovels will be affixed to the exterior of the vehicle.
Below are two images showing both the larger and smaller rear head rests used in various markets and their position at full extension in relation to the Shelf and Under Shelf Compartment. While close, there is a small amount of space remaining between the rear of each head rest and the Under the Shelf Compartment which could could be repositioned if desired. There is more than enough room between the head rests and the Shelf proper to alleviate concern. HTH
Just ordered the camping table that fits under the roof rack. They sent an email out giving 25% off. Looks like out may be discontinued once stock is gone. Free shipping too! If you order choose to pay in Euros. It will save you about $12 than paying in US dollars.
📢 Warehouse Clearance Sale – 25% OFF Under-Roof Rack Table!
Enjoy 25% OFF our Under-Roof Rack Tables during our Warehouse Clearance Event!
⚠️ Limited stock available—once they sell out, they’re gone forever! ⚠️
If you have a bison gear roof rack and run cables on it then I highly recommend this little 3d printed zip tie holder. It mounts into the channel using the regular channel nut and an m5 screw. You lay the cable into this and it has little channels for zip ties.
I 3D printed 50 of them at a 3d printing service in abs for $40. Note the guides that orients into the channel to prevent them from torquing around the nut for perfect alignment.
I'll post the 3d file into the forum collab place for files.
I also ordered some more bison gear including the rear small door interior molle. I have the wolfbox camera in the big door and I don't know if the mount would work for the big door with the camera behind the glass. Anyone know?
Same issue. I just used a grinder to notch out where the camera goes and also trimmed the right side of the internal mounting bar. Super easy.
this is a great idea. i don't have a printer though. any chance you are interesting in printing a few off and sending them my way? i'll pay you.....
How many do you need? I got 50 but i probably only need 15-20 of them.
I'm going to mount a couple on saturday (i havent mounted them yet). I'll take a pic so you can see how it looks when installed.
Just installed my Bison Gear Left and right Baskets.
Very fast shipping (poland belgium)
Very well packed, with screws and manual.
Very easy install
Very nice fit, good use of that lost space.
Only negative is that under the left basket the plastic cover, to get access to the crank, is very difficult to get back on when the basket on the top.
The way i did get it back on, is by reaching with my right hand under the cover and get the pins in place to click them in the openings. A bit tricky, so will probably not use that extra space there.
Very easy install
Your experience exactly like mine.
Another install challenge is keeping the bolt spacers secure when offering up the baskets for fitment. Had to use some insulation tape to prevent everything coming apart.
Very happy with the product.
