AUSTRALIA: Third Party Suppliers for the INEOS Grenadier and QM
SupaFit has confirmed to me their seat covers are now available for the Grenadier.
Order via email or phone. They will be listed on the website in due course.
EDIT: I have ordered SupaFit canvas seat covers to replace the loose fitting INEOS seat covers.
@TheDocAUS I purchased and have fitted the front and rear SupaFit covers (Black Denim). They took a few weeks to arrive, but simple to fit when you follow the instructions. They still have a "new" smell which is taking a few months to evaporate. And BTW, thank you for your Deutsch, crimping and other posts.
Ordered a set early September and they arrived a few days ago. Excellent fit and finish. Grey denim for the front, and grey heavy duty canvas for the rear seats to take the punishment from loading stuff in and out when the seats are folded flat.
Not having a crack at you, just was hoping to keep my money here rather than ordering the bracket from the USA (don’t need all the other gubbins).
Just but the Vevor (ARB look alike) and save $650 on the compressor alone. Then find a local aluminum fabricator and get the plate made up for $60 bucks.
Updated especially PAK Offroad, they have a new roof-rack water tank where you can also mount your recovery track onto. Not unlike Razed Products who have a roofrack tool box you can mount the tracks on as well.
TANKS – WATER AND FUEL
  2. DUNN & WATSON water tanks here;
  3. The generic Jerry can used for fuel and water is commonly available. They can be carried inside the car (water), on the roof rack or molle panels on the car;
  4. PAK Offroad has a water tank for the footwells in the rear, or a new roof rack mount with recovery tracks called the RACKTANK (unknown if the TUBTANK or Wheel arch tank can fit into the QM tub); (thanks to @globalgregors and @Rok_Dr);
  5. VAAST has range of water tanks that can be mounted on a roof rack, inside the car or on Molle Panels;
  6. BOAB Offroad has fuel and water tanks, look here; and
  7. ORS can fit stainless steel water tanks (including for the Grenadier, I have one installed), look here.
Neat! I like how these and the top shelf can still be fitted if you have an Ineos Cargo barrier. Prices are reasonable and the fitting instructions are well written.
Cheers
Steve
KAON Shelf, LH & RH Molle with Ineos Cargo Barrier. More than an hour to install but very happy with the finished job! Tip: there are a couple of rubber "rings" to use as spacers for the Ineos Cargo Barrier. Best to soak them in very hot water before trying to stretch over the fitting.
Awesome. Ordering mine next month. Hoping the molle panels don't have too much flex in them, to mount a second shelf below the cut out sections full width. Maybe a support in the middle, Then I'll have another shelf just over my fridge. Big enough for frontrunner boxes
Updated, added Brown Davis.
BATTERY BOXES
See below.
There is a new supplier for the INEOS in Australia called EURO FLO: https://www.euroflo.com.au/expedition-equipment-1
I will be adding their products to the list in the coming week. Two products are out or deing tested with more under development including a roof rack, rear table and charger mounting plate.
I will add the rear shelf and the cargo solution (currently under testing).
NEW MOUNTING PLATE COMING - 120S AND 250SE
There is a new mounting plate under development for the CTEK 120S and 250SE in Australia. I saw the first prototype today, it still needs to be test fitted. It is designed to work with 2 and 5 seaters models.
Stay tuned.
Custom Offroad now have bash plates for both Diffs and rear trailing arms listed on their site:
I will add them.
Updated, points 2 and 3 are new.
UNDER-BODY PROTECTION
  1. Custom Offroad, look here;
  2. Custom Offroad diff protectors here;
  3. Custom Offroad Grenadier Trailing Arm Protectors here;
  4. XLW Parts’ Front Differential Guard here, other parts not far off;
  5. Almont 4WD from Spain, look here;
  6. Rival has some, but Rival Australia is not showing any INEOS underbody protection at present; and
  7. Overseas, SPP offers quite a few options, for a price.
Updated links and reviews
BATTERY BOXES
Some Battery Boxes reviewed here. The Hardkorr BB was the winner but the DRIFTA, KickAss and Thunder are also compelling (and for some even better).
  1. KickAss Battery Boxes. My mini review here;
  2. The DRIFTA Battery Box. My mini review here;
  3. Hardkorr Battery Boxes (also marketed as the CAOS Power Battery Box);
  4. Thunder battery box customised by Accelerate Off-Grid Touring, or just the based model Thunder Battery Box here;. Also marketed under the name Drivetech 4x4 Heavy Duty Battery Box - DT-02008. My mini review here;
  5. Thumper Battery Boxes here;
  6. Ardent Battery Boxes here (with 1200W inverter);
  7. Mueller Energy Lithium Battery Box here (no DC to DC charger just a BMS);
  8. BMPRO Power Station (with built in inverter and 12 power outlets);
  9. Baintech Lithium Power Tops in 150 AH and 200 AH sizes.
  10. JTS Power Easy here;
  11. REDARC GOBLOCK (Premium pricing) here;
  12. EcoFlow DELTA 2 Max (you need an EcoFlow alternator charger to charge at the full rate, the cig socket is limited to 8 amps, thanks @Loc Nar);
  13. Entry level ARK PowerPack 3 here;
  14. The whizzbang POWER BOX Premium range here (3 models, 6 colours). Super premium pricing;
  15. Not really BB’s, but Enerdrive-Dometic is famous for their 4X4 Canopy Power Systems. More suited to a canopy on the QM Cab Chassis. I am not aware on any install in the IG. A new level of pricing compared to the BB’s. Tool Box Centre offers something (Redarc gear) as does MW Toolboxes (Victron gear) and Projecta Power Boards (Projecta gear);
  16. National Luna Battery boxes here (2 colours);
  17. Brown Davis DYI powerboard (5 models);
  18. Battery Box for the DYIer here (by MSA4X4) and Front Runner offers something similar here; and
  19. The Power Easy Expedition Battery Box here, with Expedition Weatherproof Lockable Case, DC to DC Charger, AC Charger and Inverter.
I bought both items, they arrived today.
