Who is experiencing software or electrical gremlins?
I reached 5,000 miles on Monday and unlocked the "Christmas Tree Cluster" feature. :]. Had the recent software update loaded during service for the door button recall. Picked up the Gren on Monday from the dealer. Drove 4 hours that night. Drove for another couple hundred miles over two days. And then this happened Thursday afternoon a couple hours into a seven hour road trip. I diverted back to the dealer where the service team is sorting it out. No word on a cause yet.
Wow, flashing alternating ones, that’s a real Easter Egg one.
I have since days no "P" anymore. The transmission refuses to go in "Park". Always jumps on "N"eutral and flashing there. It shifts while driving just normal. But if I put the car for a stop, it's not going into "P" anymore. But I don't like the feeling, just to trust the good old e-brake alone.
Anyone else hat this issue? BTW, yes, all doors are proper closed and yes, Batterie is charged, and everything else is just as it always was. The menu, there is no error shown. It just has the hint to put it in "P" for starting (but starts just fine from "N" - luckily, because "P" doesn't work 🤣 - I'd be stranded on my overlanding trip through Bosnia)
I have a lone PDC sensor acting up consistently. On the front bumper, the middle-right sensor almost always triggers as I roll to a stop. After I stop, the beeping will usually stop, though not always. And when it does stop, it often triggers again while at a stop.
I suspect that it needs a recalibration, it's ever so slightly unseated, or a rather large bug impaled itself upon the sensor.
Have you tried to clean it well with some alcohol?
Worth going on Google or YouTube with the question’ZF Gearbox won’t engage Park’ or something similar. Same box fitted to many cars. At least if you need to see the dealer, you will have a better idea of potential issues.
Just get the dealer to swap them out. I had two replaced and no false alarms after that.
If nothing makes sense check the engine bay for wires that have been rubbed through and are shorting out and sending dodgy signals.
My technician found this after perhaps the 5th trip to the service centre.
Including being towed, and all manner of adblue sensor replacements.
It was only after an engine fault code was detected which said check wiring. Since then (touch wood) smooth sailing
An unavoidable problem with modern electronics, even when the IG has less than other modern cars.
Yes, and without full wiring schematics it will be impossible to track shorts, ground faults, and corroded connectors. I am disappointed schematics are not in the Ineos workshop manual.
Isn't it more or less industry standard to produce wiring diagrams?.
There are some earlier schematics here:
Plus some basic information here (fuses):
and here (busbars):
and here (wire ends):
Lastly, the Rok Dr Guide has quite a bit on electrics.
We do known quite a bit now, would an updated schematic be handy? Yes. Are we clueless? No.
and here (busbars):
Lastly, the Rok Dr Guidet has quite a bit on electrics.
The electrical system schematics document will be most valuable, thanks! Your guide fills in many gaps.
Really It would be nice to have the theory, operation and trouble-shooting of the various modules also. I think most people in the U.S. are familiar with AllData and similar automotive data services. That's the type of comprehensive information which would serve us all very well in 5 years when we are all out of warranty.
Again, why aren't updated schematics included with the workshop manual? Any repair tech will need those too.
