Well I tried
Im not going to disagree but after the work, we have had some good rain and no leaks. Since no one sees it I am not complaining.
My safari seal has a layer of clear silicon sealant that overlaps the gasket and the metal roof.
For your car , they seem to have sealed between the gasket and the metal surface
This is what I am saying about these roofs.. worst case scenario- go to town with a caulk gun and it will be waterproof….
Here are pictures from today. Some on how it looks with them closed and then window out. You will notice they went wild with the sealant and even used the sealant on the rubber grommet that leads to drain hole. Since I was up there, I did clean around the seas with just water. I have a sunroof cleaner kit that I will use as fall wraps up. I also use canister of compress air to blow down the drain holes from time to time.
Thanks for the information.
Mine has the main seals glued in with black silicone. Nothing has been done with the drain hole, I think. The glass is clamped down firmer than it was. The seal on our glass seems to be pressed against the roof so a s to stop the water getting to the initial area that tje water would collect and drain from, is this correct. I'm guessing it has different seals around the glass? This is what I told the dealer that it needs to stop water initially entering the collection channel around the current only seal.
I definitely stand by my comment that someone isn't doing their job. Globbing that shit around the gasket did more harm than good. WTF man, tell these turds to replace the goddamn gasket! An they OWE you a new headliner. Holy f**k.
Just the other day I scrolled past this thread and thought to myself "well, at least I don't have this issue". Today I discovered that I do indeed have this issue. At this point, I am just afraid to read this forum.
youre getting a wet floor from condensation?
My drivers floor is always covered in water. I have the rubber floor mats on top of the regular floor. All the water collects in the mat and evaporates within reasonable time frame.
Additionally my rear and back side windows all leak. Dealer "Couldn't Replicate".
Would you buy one again?
