Vehicle mounted twin air compressor
Global Grenadier 76
2:59 PM
Hello TheDocAUS:
I used the anchoring of the fastening ring at the rear right (standard). I made a bushing to bridge the recess. This is connected to the rear plate of the air compressor. If the distance is correct, the side bolts/nuts of the compressor can be fastened to the back plate.
I did not want to drill any holes etc. The only thing I had to change was the cable harness feed-through in the lower small cover. I routed the wiring harness to the front of the auxiliary battery.
Regards Markus
Any pics during install process you can share?
Jean Mercier
GG#920
8:59 PM
Sint-Martens-Latem, Belgium
Hi grenadierboy, That is a very nice clean install. Is that a single cylinder ARB? DaBull
I would say yes, because I think the "twin cylinder" doesn't fit, unless I am wrong.
I finished my ARB single cylinder compressor installation today (it almost didn't 🌦️ and no work)
I will post some pictures and tips and tricks today or tomorrow, but most inspiration I got on this forum, thanks to everybody who documented their compressor install.
Nocrays
3:59 AM
Mandurah, Western Australia
Im keen to flatten out the area over the wheel arch. Im not a fan of drawers so like to have a nice squared off cargo area.
Investigating producing a replacement for the plastic panel out of Aluminium and providing a space on top of the wheel arch for the ARM twin compressor. Then plumb it to a tank under the vehicle near the adblue tanks.
LeeroyJ
10:59 PM
Arizona, USA
Third vote for them being hot and loud. I've got the ARB twin mounted in the cubby, just aft of my right rear wheel (Tacoma). I've had one electrical fault, but no mechanical problems with the unit. They are pretty tough, but I'd prefer to have it inside the vehicle. I'm pretty sure it will last longer and be more reliable if its inside the cab some where. No way around the noise and heat though. Its a conundrum...
A friend of mine and I each bought the twin ARB for our LC200’s in 2012 at the same time. He had a VXR with electric seats (so not enough room to mount it under the driver’s seat), so he ordered the Slee mounting kit and mounted it in the engine bay. I had a GXR with manual seats so mounted mine under my seat. In November 2023 when I sold my 200, my twin compressor was still as good as new. He was on his third. They had about the same use (we camped in the Saudi desert together and each had 35”s). There were two differences: the first, the heat between the air conditioned air mine received and the engine bay air his received. Second, and probably more important, if I accidentally hit the switch with my knee, I could immediately tell it had done it. If he did, he may not know for days (since after filling the tank, it only came on when pressure dropped). Take that anecdotal evidence for what it’s worth when considering mounting locations (nothing?).
Global Grenadier 76
2:59 PM
I agree totally - it's such an odd thing that IA didn't do something here to be more practical.
ADVAW8S
Global Grenadier 0044
11:59 AM
Kirkland, WA, USA
Um, I think IA was forward thinking, they slapped a laptop sticker on it. This was built on purpose as a laptop work station. Now you can squeeze yourself back there to knock out that email
Global Grenadier 76
2:59 PM
Or maybe a live broadcast for a podcast.
Right @Stu_Barnes ;)
Jean Mercier
GG#920
8:59 PM
I saw that also. What do you guys think about the placement of the compressor? I’m not sure. Looks a bit forced.
I don't like it either, it takes too much space in the boot. It is of course a quite easy install, compared to the "one cylinder ARB" install behind the secondary battery (space is very tight).
7:59 PM
Yeah - not ideal.
I know most people will be keeping the second row of seats, but some of us are planning on doing the rear seat delete from Goose Gear. I'm thinking there will be somewhere in this set-up to mount a compressor. It looks like there is a big overhang - i.e. the flat floor extends over the box that contains the batteries and other electronics. It looks like it might be possible to mount a twin ARB somewhere around where I put the red circle.
If @GooseGear has any thoughts - be great to hear them.
P.S. I'm not interested in the single motor compressor mounted inside the electronics box, for two reasons: the single is a little slow for four tires (particularly if the tires are 'oversized'), and I think it might generate too much heat in there.
Photo from Goose Gear: https://www.goose-gear.com/products/ineos-grenadier-2024-present-second-row-seat-delete-plate-system
Strib81
12:59 PM
USA
ARB Twin Compressor installed behind trim!!
Had to relocate ac inverter and build wiring harness extentions as well as custom mounts for everything.
Global Grenadier 76
2:59 PM
Is there enough air circulating to cool the compressor?
6:59 AM
There's only one way to find out!
Anyway , once you start removing panels it's popped the cherry of boring holes in things :D Don't worry about the "next owner".
Strib81
12:59 PM
USA
The twin compressor has a cooling fan to circulate air. Notice the vents on the trim panel. They are directly above the compressor air intakes. So I believe the answer is yes.
