UNAVI DIY Rear Mirror & 360 Camera System
mechdriver
3:36 AM
NY, USA
I recently ordered and performed a DIY install of the UNAVI rear view mirror and 360 camera system.
Originally I was planning on the Wolfbox G900 Tripro with the 67 designs adapter but after watching the demo from @bodhigrenadier on YouTube I convinced myself to try it.
After ordering they asked which shop was doing the install (me) and promptly shared the install instructions, which included links to disassembly, installation and calibration videos.
I installed the rear view mirror system first, which unlike Wolfbox completely replaces the OEM stalk. Installation was straightforward for anyone technical, and besides a few odd things like unused wires for the rear camera and the installation PDF being very simple in English but the videos being either silent or the tech mumbling in Korean, it was adequate.
The rear view mirror camera system includes a front facing camera to mount near the stalk and includes DVR features so it’s a great dashcam. The UI is simple (I think Wolfbox has more features, but I can’t really say) and it’s so much better than relying on the pathetic manual rear view. It almost too good and I’m not accustomed to these camera systems but you get a great wide shot of the rear. The install took me about half a day, mostly as I was trying to be very careful with my trim pieces and I spent the time to route the 2 camera wires through the rear hatch for the 360 system. The “mirror” looks stock and has simple features to lock a recording, switch front and rear and mute the mic. I will say the crash detection to lock a recording is a bit too sensitive for the Grenadiers ride quality!
The 360 camera system install was also straightforward for anyone technically inclined, but it took me an entire day. The rear was easy, I added wire loom covers in a few spots. The side view requires disassembling the door cards and removing the side windows from their tracks. Once you know how it’s done, it’s quicker. Their disassembly and install videos help, but I also find they are doing a quick job, maybe not a perfect install, and there’s a few things I would do different to ensure long term reliability. The front camera they route through the fender and poke through the door wire harness gasket. I opted to route through the firewall where the trunk release grommet is. Much cleaner and can be better assured of a seal.
Once I had everything routed the absolute beast of a job was getting the connectors disconnected from the factory head unit. One connector is only latched from one side and you can’t remove the unit so you’re really struggling to get the clip to release. Once that was done, I was able to fire up and it works great, as described. I need to calibrate and test further.
Overall, it can be a weekend project for a technical person or if a shop does it expect 2-3 days labor. I will update his thread as I calibrate and use it further. Overall I’m excited.
Great write-up, thanks for sharing your experience. That head unit connector is a real pain, glad you got it sorted. Sounds like a solid system once installed. Looking forward to your update after more testing.
Thank you for sharing. I am considering a DIY install over the holidays.
Did you need any speciality tools (or any you found useful) and did you need to replace any single use clips/seals? Trying to get an idea of all the items I'll need for the install.
Thanks!
Thanks!
None of the clips broke and if you work slow and methodically the trim pieces should all cooperate.
Toughest parts were:
-Getting the wires through the rubber door conduits. Use some soapy water or wire lube and a plastic rod as a snake. Expect to disconnect the ends and then refit them.
-Releasing the side windows to slide the window up manually. There’s a specific spot your pushing to release the window, which you then lift and tape in the upward position. Instructions show this but not specifically enough to know what you’re supposed to press on.
-Front camera they run through the quarter panel and then pierce the rubber door conduit. I did not like that so I routed it through the engine bay and through the grommet for the hood cable release.
-Removing the ADAS camera assembly and rear view mirror are daunting at first but actually quite simple.
-One of the OEM head unit connectors is a monster. Took me an hour. The install video you can hear the guy get frustrated too. Having an inspection mirror, a metal pic or small screwdriver help.
Besides that it’s all just careful wire routing
Thanks for the additional detail. Going to try the install at the end of the month - most concerned about the glass and ensuring the head unit plugs stay in order and in shape. Planning to go slow in parts.
I already have a wolfbox digital rear view mirror so thankfully don't need to deal with the ADAS camera from what I understand.
Cheers
Great info, can you tell me if the rear view camera shares video to the 360 system. Reason is i would like the 360 but already have a rearview system installed and was not sure if it had to be replaced? Also were is the rear camera for the 360 mounted?
Regards
Gary
Can you share some photos of the replacement stalk for the rear view mirror please? I looked on their website and there’s not much to go on.
Thanks.
Regards
Gary
there 360 system is completely independent of the rearview mirror system. You can have either without the other. The rear 360 camera replaces the standard Ineos supplied camera in the lower rear door. The rear view camera sends video to the mirror screen not to the central console screen. I have the wolf box 900 rear view camera and the 360 system. They are a great combination and transforms the ability to manoeuvre with precision and safety (incl parking in suburban car parks)
Regards
Gary
As has been said already by @ddv they are independent. UNAVI offers a 360 camera and a standalone rear view mirror system. The 360 camera replaces the factory rear camera with a higher resolution one. The rear view camera has you mount a new camera on the rear glass of the larger door.
Thanks.
I can get pictures later but the UNAVI stalk replaces the factory one completely. There’s an epoxied mount on the window and the UNAVI has you transfer the OEM clip to their stalk and it just locks in through a quarter turn or so.
