Steering stabilizer bar
Driver's side bolt partially screwed in. Just need to tighten it. Hardest part is blindly aiming (oxymoron) the bolt into the nut while aligning the second washer. Would be much easier if vehicle was on a lift.
Can you explain what you mean by washer? I had no washers come with my steering damper. Nor were there any washers in the stock hardware.
I recommend the use of a dead blow hammer with a non marring face. That should dislodge the bolt without causing any damage.
agree...put head over a sturdy mount that is open in middle or over spread jaws of vise...and use deadblow hammer to knock out. Even if rusted should knock out especially if soaked in PB BLaster overnight. It just slides in does not thread through that part. Good luck. Or look at head of it and find a replacement bolt...I bet Agile Offroad can give you what is used if cant determine on own.
Is that a sleeve around the 18mm bolt? Or is that just discoloration from the rubber damper?
There is a sleeve fitted, from memory it goes on the outside mounting point near the wheel as the bolt is thinner than the inside one. The LHD differs on the inside mounting point in terms of the bracket being tucked further under, not sure if it differs on the outside or if they use different bolts.
Is that sleeve reused? I think for the Agile damper they say to keep it ziptied to the stock damper so I assume not reused.
I can definitely try that when I get home. You sure it isn’t threaded? Nothing to lose I guess.
Mine came with the washer/spacer seen attached with a ziptie in this screenshot...
Maybe your stabilizer is a newer design that no longer needs it?
If your local dealer does not have the bolt you need in stock and you don’t want to wait the sometimes months it can take to order parts from INEOS, I’ve found the website belmetric useful for sourcing hardware. I don’t know the exact size bolt you need so this link is just representative
I use Belmetric often as well.
There is absolutely a sleeve on the stock part. The new unit will not require a sleeve.
Anyone know what the thread pitch should be? The bolt is proving difficult to source from dealer.
For the M12 bolt does anyone know if it’s M12/1.75 or M12/1.5?
Sorry I haven’t
followed all this thread and I don’t know the thread pitch but bolts for the shock absorbers front and back are M16 x90. This is for the M23 catalogue which is what I have access to
Thanks Logsplitter. Well I found another dealership to send me a new OEM bolt. Part number is GRA-0000-003390 and it’s an M12 10.9 grade 80mm flanged bolt with partial thread. He could not tell me the thread pitch.
I’ve just read back through the thread and realise you are talking about the steering damper not shock absorbers. I just saw pictures on the last couple of posts and assumed it was a suspension shock absorber. Silly me ☹️
Have you tried localised heating of the sleeve, it should loosen somewhat...;)
@Chadd7: I misunderstood...sorry. I hadn't seen your previous photos. I'd suggest rapid cooling, not heating!
You could put the stabiliser in the freezer for 24 hrs. If there's corrosion between the sleeve and the bolt and/or the eye mount bore, the freezer temp of -18degC/0degF will induce micro cracking of the corrosion. This is the basis of the 3M aerosol "Freeze and Release" which from personal experience is very effective for rusty bolts. It may even work on your current challenge. Apart from rapidly cooling effect inducing the cracking, the aerosol 'carrier' is a low surface tension lubricant which works its way into the minutest of gaps making it easier to slide the captive surfaces....
Just an FYI, the latest version of the Agile steering stabilizer has the washers attached.
Finally got it on! Big thanks to all of you and to Paramus and North Shore Ineos for sending me the new bolt. I could not get the old one off. The driver side steel bracket would not fit the new steering stabilizer by about 2mm so I used my brake piston tool to spread it open to fit. The steering is much improved indeed!
Glad to hear you like it. Seems more and more people are buying and chiming in about how much better the truck handles. Go figure.
