Installed NEW Fox 2.0 ATS Steering Stabilizer June 2025
Nothing is different steering setup wise between US & UK markets (besides the obvious LH/RH) that I’m aware of. And I don’t think US owners are auditioning to be in the next Hitchcock type film featuring a rear projection scene while driving a fake car. :)
This is more of a road condition issue coupled with a very stiff or high rate steering stabilizer, and typical for the design, central dead spot in the steering box. High stiction in the system means you have to turn the wheel through or past the dead spot to have any meaningful change of direction. Countries with more curved road systems where you are typically moving back and forth through the dead spot and against the stiction as you drive along so any waywardness would be less noticeable I would think.
It’s not uncommon in the US to encounter asphalt, concrete, course road grade, high cambered, crumbling and rutted road surfaces over the course of a short distance on a single highway system (Yeah, our road infrastructure sucks as well especially in the permanently under construction Mountain West). Also, it’s not uncommon in the West to travel 25 to 50 miles at a time on basically an arrow straight road with no curves and poor surfaces. So a slow steering ratio coupled with a rather stiff stabilizer often means the steering responds to an imperfection on the road and takes a set and without a correction you can easily start to move out of your lane especially above 60 MPH.
I own plenty of old Land Rovers with the common Adwest steering box design (which basically perfected the notion of vague steering feel) and the Grenadier’s is very similar in feel overall but I’d go as far to say even my restored Range Rover Classic is a bit less fiddly on the highway requiring much fewer corrections at the wheel. Then gain, the weight of the components and geometry is obviously different between the vehicles.
I’m not complaining about the steering in the Grenadier per-se, as for the most part it works for what the vehicle was designed for but I’ll take a small improvement if a legitimate one exists especially since switching out the stabilizer takes only a few minutes. I will freely admit the steering has improved slightly as things continue to break-in and become a bit smoother. I’m not looking to change the entire character of the steering system and actually prefer the overall heft but a bit less steering correction would be most welcome on longer drives.
I just threw on the GrenX Bilstein steering stabiliser. Easy lazy 10 mins. No adjust. Works great straight out of the box. Better straight line tracking now on highway drives, and also now mostly self centres too which is nice around town.
I installed the Fox ATS from Owl. I have it on 12 clicks right now. It really transfromed the steering... I have 800 or so miles with it and am glad i popped it on.
Does anyone currently do an adjustable steering damper that does not lessen the ground clearance on a Right Hand Drive vehicle?
Having run with no damper for a week or so on roads, the difference is very discernible, but I also appreciate that the stiffer steering will be much more beneficial when it comes to more challenging stuff.
I suppose we are looking to get the best from both ends of the range, but without compromise.
Is this maybe too much to ask for at the moment?
G
G
I can't imagine you couldn't adapt or have someone adapt a FOX ATS to your truck. I know y'all's is different, I'm just not super familiar with the right hand setup. Do you have an off-road fabrication shop near by?
I installed the Fox ATS from Owl. I have it on 12 clicks right now. It really transformed the steering... I have 800 or so miles with it and am glad i popped it on.
quick update: I have 4500 miles on the Fox ATS and running it on 14 clicks.... love it
G
Yes Tough Dog Australia make a 9 way adjustable steering damper for right hand drive Grenadiers that does not affect ground clearance, and it is relatively cheap, $230.00 Australian, so about 110.00 British pounds.
It has been available for Ineos Grenadiers for just over a month, so relatively new, but versions have been used on many other vehicles in Australia for years.
Cracking price for a proven off the shelf adjustable, might give one a try. Hangs down on a RHD just as much as any steering damper.
But I would install with the dial facing backwards.
There is a stockist in Girona for the Europeans, I believe La Vuelta had a rare (for that area) stage nearby yesterday.
My Overland Shop
This is interesting! Cracking price. It states they fit 2024+ Grenadiers, does anyone know of any reason why they wouldn't fit 2023 models?
Sorry I meant no lower than the standard damper, and I installed one to slightly improve my turning circle, and I did mount the adjuster backwards.
The steering is lighter, but that was not a concern for me, and it is very well made, and it gives you about 8mm additional travel each way.
The factory damper is gas pressurised and slowly expands to full open, the tough dog unit is neutral.
Too late for me I'm afraid, we went with the fox adjustable.
Just put the oem back on for going anywhere off road when required.
milltek are supposedly developing a system to address the ground clearance, but having it installed i think this will need to be quite substantial as there doesn't look a simple work around to raise it out of harms way.
We'll see.
Hopefully someone else can benefit from your discovery.
G.
It is weird watching the factory damper self extend when you take it off.
How much variation is there on the different settings? Can you dial it up and make it close to the factory damper stiffness if heading to the gnarly stuff?
The original Tough Dog steering damper stiffness test I did was pushing on setting 1 to pushing on setting 9 compared to the removed factory damper, I just did a test after about 3000km, including 500km of that on dirt since fitting so definitely run in.
Setting 9 now that it is run in, "just tested a moment ago" is probably similar to the factory damper from memory, and setting 1 is what I leave it on on the road, and setting 3 on high speed dirt, so far so good.
