Quarterdeck- ADVAW8S QM build thread
ADVAW8S
Global Grenadier 0044
Quartermaster Owner
6:17 PM
WA, USA
This thread will be for my build of QM. I look to share ideas and also ask other forum memebers to share ideas or solutions.
I have named the thread Quarterdeck after the military term used for area where senior officers work. Since I will be the captain of my ship, I will live and work in Quarterdeck.
Wolfbox: the rear view camera can be found in tailgate. Plus their is no obstruction in the rear window. But I will be installing an a rear camera when I have the back fully covered. If you get the G900 Pro kit, it comes with a rear plate mounting kit. It an only be used on USA plates https://wolfbox.com/products/wolfbox-g900-4k-2-5k-touch-screen-parking-monitoring-dash-cam
Step plates for rear bumper: I was rewatching the powerful UK video on the QM and Simon pointed out that the rear bumper could use some step plates for those times you need to step on the bumper. Found these for the SW but bumper is shared with the QM.
I believe the centre of the rear bumper is steel. What Simon was referring to in his video is some kind of non slip attachments on top of the bumper. Might try self adhesive non slip tape if needed.
It's not that slippery. I've used it often with work/hiking boots.
But you could add grip tape.
The checkerplate thingoes wouldn't improve grip and at that price...yikes!
It's been a year since I started this thread but it is time to get it going.
This week started the build process and I will post pictures soon. On Monday, I added Wildpeak 255/80R17 to the OEM steel wheels. I took the advice and had them place the sticky weights to back rim to keep a clean look. Then on Thursday, the RadFlo shocks were added. I had a speciality shop install as I wanted a alignment done since I had new vehicle, new tires and or course new shocks. PXL_20250424_233657374.MP.jpg
You can see the QM was way off and I still drove fine. Once they adjusted it, it excelled.
I'll give more feedback on Radflo as I get more seat time but initial impression is good. The suspension shop does work on high end vehicles and asked me a ton of questions on how I plan on using the truck. What plan to carry, how often, etc. The set up was for general use so the shocks soak up the bumps on highway and even long speed bumps at 30mph. The shop also increased my tire pressure to 49 in rear and 40 in the front. When they explained it, I expected a stiff/harsh ride with E rated tires and a light truck. While the SW comes in a 7k pounds, my Quartermaster is only 5960. Not skinny but not bloated. The ride is super smooth and not harsh at all. Driving characteristics, very little body roll and no dive in front when hard braking or front lifting on hard acceleration.
I plan doing some interior work this weekend, with American size slurpee upgrade, tougher seat covers and other bits and bobs.
FWIW, those pressures are intended for 4270lbs on the front axle and 5070lbs on the rear axle; or a combined 9340lbs; especially on the rear I'd recommend either doing a chalk test across the tread or watch the tire wear over the next few thousand miles.
Falken's inflation chart is available here to see what tire load equates to what required pressure
Will do, the alignment shop has me come in for free every 4k for them to look at wear. No cost no appointment, show up and they check to make sure the alignment is all good and wear on tire is in good shape. Thanks for sending the chart.
Quick evening update. I added the Grenadier USA cupholder, I bought carpeted floor mats for summer and then I'll get weather tech for rain season. The carpet is nice and low cost solution. It even has a heal pad. I added a non slip pad to test it out on area above steering wheel. If it works and I like it, I will find something that looks better. Finally, taking page out of the group, I got a large O ring to put on the NATO plug to prevent water intrusion into the cap.
If one does not want to cut out plastic or metal on the rear bumper or tailgate, the Wolfbox reverse camera plate bracket does fit neatly behind European plate holders as well. With the G900 Pro rear camera there is ample space left for opening of the tailgate, and when driving with opened tailgate rear camera view is not impaired. The mirror itself fits conveniently between the Rosen visors. Would have loved a three-channel version which was not available though when I ordered early this year. Tow hitch self-ducking after having been ducked.
Today added the Suma in blue. I remember early on @Jean Mercier cracked his rear light brake lights off roading. I didn't want metal guards is back. On my search I came across smoked tail light covers. I was unsure but I liked the look once I put it on. The hope it adds a little protection. Maybe not everyone's flavor but I like it.
Today, I put racing optics windshield defense on. I order it for 250 and my neighbor helped me install it. Took longer than expected because we took our time. We will see how it holds up but I have new appreciation for wrap people. Directions from racing optics were easy to follow.
I also replaced my screen protector of the center stack. I installed a anti glare one and botched it. Order another one, thinking o got anti glare but I got anti finger print. Glare will not be an issue once I get windows tinted.
I also replaced my screen protector of the center stack. I installed an anti glare one and botched it. Order another one, thinking o got anti glare but I got anti finger print. Glare will not be an issue once I get windows tinted.
I was looking at ordering the windshield kit as well. Where do you get the screen protector?
First one from
Order second one from Amazon
Had L track added to the bed. When I ordered, I thought it would be just bottom of the bed. When I arrived to pick up my truck as they did the canopy, L track was on bottom and side of the bed.
Did you ordered the rails somewhere or the guy made them on purpose? I could not find anything matching exactly the length and bolts spacing. I had to recut and drill Amazon bought rails. Does the job but not as nice as yours.
The dealer ordered them for me. Again, I was surprised it was on both sides.
I didn't order on mine, as I figured they would just fill up with dirt in the back. Did not know they were mounted on the sides also. Might look into a set now.
Little lagging on this post. Here is an update. I am pretty much done with the outside for now. Looking at a winch and a flat tray but until then, moved to interior.
I installed a Subwoofer this was a kicker I bought off of Amazon that was refurbished. It's meant to be a temporary solution. I appreciate everyone's help chasing down wire schematics. I finally rolled the dice and figured out the wiring. Looking to move up to a amp and bass. Will probably order from sim sounds as they provided a great speaker system that was installed. V2 set up.
Installed Midland 275 radio. Attached the antenna to the lashing bar via jeep roll bar mount. I then ran cable through the ext power and in Pillar B. Then attached it to the back wall of the QM. I attached the radio directly to battery since the one and off is done via the mic. I then ran the cable along the transmission tunnel and into the driver side center console. I cut into plastic for a adapter. Now when mic is not in use I put it in front seat pocket of my Tougher seats. The mic attached to holder that I got off Amazon. It color matches the interior and goes with the overall set up.
