Probably dumb Fox adjustable stabilizer questions...but I'm gonna ask anyway
HRJ
9:06 PM
SE TX
Do I re-use the metal sleeve that was used on the passenger side of the stock stabilizer? And are the torque specs really 85 ft/lb on the passenger side and 135 ft/lb on the driver side? I didn't go that far when I installed mine last night. Felt like I was gonna break a bolt. Especially on the passenger side. I never felt a sensation of the the bolt getting close to a "can't turn it any more" point.
Advice?
Advice?
I installed per AO instructions. And I did torque to 85 and 135. No problems in 18 months.
Per the service portal the torque specification is 100nm and 120nm or 74 ft-lb and 89 ft-lb.
The metal sleeve from the OEM damper would not fit in the bushing of the Fox damper I used on my Grenadier.
mine either, just making sure.
OK, I’ll keep turning the bolt. Just feels weird.
Use a torque wrench and tighten to 75 ft-lb and 90 ft-lb respectively. The axle side bolt does snug up slowly. It is because the Fox bushing is two parts and it compresses until the two halves are fully seated against each other.
FWIW I did mine as a 59 year old dude on my driveway in under 20 minutes.
Yeah it’s not a hard job. I just wanted to make sure I wasn’t making a mistake on the torque. It honestly felt just like every time I snapped off a bolt.
You've never been through the "righty tighty , uh oh, loosey" door?
You haven't lived :p
