Possible Side Mirror Replacement to reduce Blind Spot - Please respond if interested
BillLumberg
9:38 AM
TN, USA
I have been in touch with Eddy from Suma Performance (thanks to @Norb-TX for bringing them up in the other thread). They make aftermarket convex side mirror replacements to reduce blind spots. This would replace the mirror only, you keep the factory housing. They also offer a version with blue tint that reduces glare. Eddy stated if there is enough interest, they would make them for the Grenadier. He has not yet defined "enough interest". Judging by the cost of the Jeep JL, it appears it would be around $200 for the pair.
I tried to make a poll, but I guess it has not been turned on for me yet. So if you will respond to this thread, I will let Eddy know how many people are interested and see if that is enough for them to make the mirrors.
Thanks.
One issue i have with my mirrors is headlights behind me at night. I am spoiled and have dimming mirrors on my other vehicles. Any experience driving with these at night as far as headlights behind you?
Upvote 0
Thanks.
+1 heated
Upvote 0
No issues, they seem better than stock on that to me. Maybe it's the extra curvature on the glass but that is my subjective opinion. I've never had autodimming side mirrors only the reverse mirror in the dash. With wolfbox that is no longer any problem either.
Upvote 0
I installed the Suma gray mirrors and they are way too dark with my tint (35%). Even my wife commented on it. Does anyone know if the blue mirrors are lighter?
Upvote 0
Below are customer feedback and Suma Performance comments from the website's feedback section regarding which tint is darker/lighter.
Upvote 0
I am actually seeing contradicting statements from other reviews and also chatgpt. Another reviewer said the blue is the way to because the grey is darker. Also, chatgpt says the blue is lighter. I am asking Suma to confirm through email, i will update here when i get a response.
Upvote 0
Not for me. Unless the clown behind me is driving with their high beams. I have also found that not all auto diming mirrors are the same or good. Most have been good but my 2010 Expedition was so sensitive to light that the rearview mirror would dim to the point that I could only see 2 white dots and nothing else.
Upvote 0
Installed the other day. It was pretty easy….couple minutes per side.
Mine did not come with pig tails but if you turn the whole housing so it faces you, it makes access and working with the short wires much easier.
A plastic trim tool also helps a lot vs a metal screw driver😂
I wish the mirror would adjust further out. The mirror motor is maxed out and I still see too much of the Gren vs the lane next to me.
Upvote 0
Thanks.
I am interested.
Upvote 0
Sometimes it’s the simple things
Upvote 0
Installed mine yesterday. I have manual mirrors w/o heating and had the hope that wiring for heated were in place, but they were not. At least I have a fuse in the fuse box for it 😉
Here is a picture of both mirrors, left original, right SUMA:
On the OEM are 2 metal tongues which are not on the SUMA. To click the SUMA in place the cable must be moved outside this plastic ring.
I am a little bit disappointed about the angle gain. Not much difference. Also, I realized that the range of mirror position is quite limited. But that is a INEOS problem and not caused by SUMA.
BTW, order process and shipment went quite smooth.
Upvote 0
The angle gain is not super big, but I think you're not getting the angles right on your picture either. If you look at the pictures there's a metal post on the house behind the mirror. That post is at the edge of the Suma mirror and 25% in from the edge of the factory mirror. It suggests that the camera was farther away from the mirror in the Suma photo than in the factory photo. That will cut the angle of the mirror.
I think you'll find that it is quite a bit more than the factory mirror.
Upvote 0
I have read that the driver side doesn't appear to give you much more range, but the passenger side appears to give you more based on the angles of the driving position relative to the mirror. I haven't got mine yet but seeing as you are LHD, that may be why the left mirror doesn't appear to give you more?
Upvote 0
Ordered blue ones today. They were in stock. Discount code didn’t work :/
ahh, you are doing blue on eldorat blue. Please let us know how it looks as I have held off undecided on whether blue will look alright with eldorat blue.
Upvote 0
My OEM driver side mirror was hitting the housings top left corner and the Suma does as well limiting the mirrors travel in the housing, that said the Suma mirror gives my about 30% more field of vision at 50'. It was a completely worthwhile for me.
Upvote 0
