Only 3 Grenadier Roof Racks Left in Stock at TrailRax
TrailRax
Supporting Vendor
5:25 PM
Woods Cross, Utah, USA
🚨EXTREMELY LOW STOCK ALERT🚨
Hey friends! Just a heads up — we’ve only got 3 Grenadier Full Racks left in stock. If you snag one while they’re still here, you’re in luck… they’re guaranteed to land on your doorstep before Christmas Eve. 🎄📦
SHOP HERE
ROOF RACK SPECS⬇️
  • Overall height added to your Grenadier- 3.68" from the center of the roof. This is measured at the rear of the vehicle, center of the hump on the roof to the top of the rack.
  • Static load rating of the rack: 1000 lbs evenly distributed across the rack. Verified in CAD and real life testing.
  • Dynamic load rating of the rack: 450 lbs evenly distributed across the rack. Verified in CAD and real life testing.
  • Safari windows can be opened and removed with full length rack!
  • 3/4 length rack will go from rear to the start of the slope on the roof in the front.
  • Easy bolt-on rack install
  • Wind deflector to minimize wind noise
  • All aluminum construction to avoid rust and corrosion, stainless steel mounting points.
Contact us if you have any questions about the roof rack, compatible accessory brands, or anything else!
Email: info@trailrax.com
Call: 385-777-2601
SEE INSTALL INSTRUCTIONAL VIDEO⬇️
