OEM Rear fog lights location & retrofit?
3:28 PM
NY, USA
Where are the OEM rear fog lights fitted? Can’t seem to find a good picture or video showing them.
Also, and it sounds silly in a car with so many optional switches, but has anyone thought about retrofitting the OEM rear fog lights to a car that was not equipped with them originally? Including replacing the LH stalk with one with the built in button?
Maybe I’m just button/switch obsessed but I thought I’d ask…
I am not aware of any OEM Rear Fog Lights, but here is what I have done with aftermarket Baja Designs units (which I also switch on in very dusty trail conditions to function as “chase lights”).
I'm in the UK, so I have a European car with fog lights and the switch on the indicator stalk.
There are the standard night rear lights:
Here is the night lights and fog lights together!
So, as the fog light are integral to the rear light cluster, it would be a good idea to look at the plugs and pinouts on the rear light cluster, as it is vaguely they are the same lights as mine!
I have just looked in the parts book and the part numbers are different UK/EUROPE vs USA
So, as the fog light are integral to the rear light cluster, it would be a good idea to look at the plugs and pinouts on the rear light cluster, as it is probable they are the same lights as mine!
I'd bet without software access they wouldn't work here. Hopefully someone will eventually break the code and give us access to stuff. I had a F150 Raptor and the whole Ford software system has been broken down and from a forum I learned how to reprogram all kinds of stuff.
