New Year Service Overdue Bug
And, very importantly, why are the Aussie reminders in the format xxxxDay, whereas others are expressed as xxxxd ??
I have both. On the main screen is says 2051 days and in settings under active warnings and status it says 2051d. I’m in the U.K.
That’s gone straight over my head after 1/2 bottle of red.
Mine was built on the 19 January 2023 and I now have a 2051 day overdue service date. Work that one out if you can 🤔. 🍷 cheers.
Need the last service reset date. Applying the signed / unsigned error, your last service date would be May 27, 2020, so that doesn't make sense.
Still not sure why 2026 would trigger the error and not, for instance, the day before. It's not a leap year so it shouldn't need any exceptional processing.
As long as there’s not a bun in the oven.
I’ve joined the club!!
TALLY (Updated)
Chook 1840 days
Itsdchz 1841 days, first US car with the pox
BrandonADV 1852 days
TahoeGren 1852 days
Pat-Ard 1868 days
Rok Dr 1869 days
Sonoranrover 1875 days
Chem409 1890 days
Duncan McDonald 1892 days
joejet 1894 days
Korg 1899 days
Grumpy 1906 days
pedrogb1915 days
OGrid 1927 days
WhiteBear 1931 days, first car outside ANZ
ecohen2 1932 days
Happyoldgit 1933 days
OkGo 1937 days
NixGrenadier 1940 days
ddv 1945 days (Aug 2023)
Tergosa 1946 days
Fred 1950 days
Camilondo 1953 days
Jeremy966 1967 days
Ex-defender driver 1968 days
TheDocAUS 1968 days (Feb 2024)
Denis M 1975 days
MattG 1989 days
Green Gren 1903 days
Phred 1994 days
douggie 1995 days
Glen 2007 days
Badger4x4 2007 days
Adam 2007 days
Baron van T 2009 days
Silverjay 2022 days
Chris Hilton 2024 days
Tony H 2025 days
Landmannn 2044 days
acky 2048 days
Commodore 2057 days
NeoGTi 2057 days
Greasemonkey 2059 days
Lollo050968 2074 days
Wile E Coyote 2095 days
Dschubba 2097 days
Stu Barnes 2097 days
Manuel4x4 2106 days
Mazeman 2107 days
Tazzieman 2137 days
Logsplitter 2150 days
Skymark 2156 days
Emil 2190 days
Ron50 2253 days
Clark Kent 2367 days
C-Mack 2458 days
NET ZERO
Steve B and Jean Mercier have no alert.
INEOS TALKS
INEOS has acknowledged the issue here.
SUMMARY
C-Mack still in the lead with the Chook as tail end Charlie. Wile E Coyote is doing much better than when he takes on the Roadrunner.
56 members listed so far, from lowest to highest number of days. Only 2 members with no alert.
If I missed you tell me.
Setting the date back to 31/12/25 and turning the car off for 30mins does clear the error.....until you set the date back to Auto and bingo you are overdue. This means that a hack of setting the dates back to clear the error does not work. My next test is to set the car back to 25/12/25 and let it clock over a day overnight and then manually set the date to the correct date tomorrow. If this fails then we are likely looking at a firmware update. Perhaps we should all take our cars back to Ineos HQ in Australia on the same day.
This appears to be a worldwide problem not just Australia. Ineos have posted to say they are aware … see screenshot.
Uncool.
My date was correct, but I still got an error message. I turned of auto date and changed it to the second, and shut it down.
Is this deliberate sabotage by some programer?
1946 Days and I had it serviced this Fall
Took both of mine down, 2025 QM with the most current software and the 2024 Gren Station Wagon that has not had the software update. Adjusted both to not have the automatic time, and even 'adjusted' the year back to 2025 thinking it would fool the system to get rid of the service notice - no dice unfortunately!
