Build Thread LOST 4X4 Build: Aftermarket Wheels and Roof Top Tent
Still waiting to hear back.
And I also don't mind the Buzz Overland but they are also double the cost of the urban automotive ones, so I'll get the Urban quote and decide from there probably. I'd probably go LeTech over the Buzz ones if spending that much money as you can use a high-lift jack off them.
I think the Urban ones look the part but by Urbans own admission, are mainly cosmetic. Black Sheep, LeTrek, Buzz are all built to withstand some real punishment.
I’m pretty certain you can use a HL on the Buzz ones with the ”peg” adapter. It was posted somewhere on here.
Hi Darby, The Buzz Overland rock sliders are already set up for a high-lift jack. DaBull
Little update on build.
Replaced the front runner load feet with the GrenX backbone to lower the height of when the roof top tent is mounted, also a bit lighter. I winch this on/off when not in use.
Installed the bushcompany 270 XT awning to the roof top tent.
Mounted maxtrax and STEDI 50" light bar to roof top tent.
Installed the STEDI micro dual touch light bar on the side of the vehicles tie down rails.
Also installed the OwlVans underseat dual ARB compressor mount.
** For Sale **
Also, I have my used "Front Runner Gutter Mounts for Ineos Grenadier x8" for sale. Based in Perth, Australia, happy to negotiate a very fair deal and post if required.
There are a few you can use Hi Lift on....if round tube sliders (White Knuckle Offfroad is what had on both my FJC and LX470)there is even an adapter for Hi-Lift that cradles lower half of tubing for a secure lift. If anglular/square like the Agile Offroad or others...a regular lift is compatible. They also have nothing to do with side airbags....as they mount to frame... I think the guys misunderstood them. I have heard of front bumpers being "airbag compliant" but that is mostly the crunch zone and timing for slowing down impact energy and airbag sensor being able to recognize the suddent stop in momentum.
I have used the White Knuckle Offroad for years...and banged, beat, used to change tires, etc....they had gouges, scrapes all over...and I would just touch up with black rustoleum hammered finish paint and keep going. Never bent...
I just ordered sliders from Agile Offroad....as didnt want to wait 8 weeks from WKOF...and wanted to try something new. You definitely want a set that is built for abuse and not just to look nice.... I trust WKOR...and have seen the AO in use in Moab and other locations...and they hold up. Good luck.
I pulled my gutter mounted FR mounts too, they cracked the paint on the forward and aft corners. Replaced them with just the FR grab handle mounts. I have the same tent too! Love it.
Damn, happy I took mine off then! Swapping it to the lower grab handle mounts has also reduced a heap of drag and saves a heap of fuel when the tent is on. Also a big fan of your setup, seen it on insta 👍
Also some build updates:
Installed my upgraded dual battery lithium system with victron gear, redarc tow pro, power outlets, little 1000W inverter and some molle for inverter and other gear to mount to in the rear. Pictures on this post: Electrical Pictures
Installed my SCFabworks rock sliders with step, very solid unit.
Also got sick of pressing start/stop, so got a little bracket by EuroFlo in Aus, $25 for product, $15 for shipping (AUD).
