Here are the Ultra High Molecular Weight plates and the front and rear diff covers! Enjoy
Then it's good that you have such a long corridor.Here are the Ultra High Molecular Weight plates and the front and rear diff covers! Enjoy
Initial thoughts oil change access?Here are the Ultra High Molecular Weight plates and the front and rear diff covers! Enjoy
When I contacted them about this issue, they said that there would be access. I’m not sure how, I don’t have a visual on it.,Initial thoughts oil change access?
Looking at the engine area a valvomax or fumoto would seem a necessity to prevent messy oil changes. Looking at the UHMV, the install of skids looks easy - let’s see the skids when they arrive!Here are the Ultra High Molecular Weight plates and the front and rear diff covers! Enjoy
Do instructions call for preassembly off vehicle for install as one entire unit?I opted for a self-install instead of the $1000 Owl wanted. I mounted the UHMW plastic to the aluminum plates. Waiting to hear back from Owl about a small discrepancy in the attaching hardware locations, but these are otherwise top notch. Nice design, quality materials, really nice powder coat, and pretty welds. The hardware is all A2 stainless black zinc.
No instructions exist yet, but the engineer recommended to do so. Instructions are being created presently. There are nylock nuts on the back side so it would be difficult to mount the plastic panels with the aluminum skids on the vehicle. I recommend an electric ratchet as there are 41 of them.Do instructions call for preassembly off vehicle for install as one entire unit?
I had the same issue when I installed my MetalCloak diff skids. Pulled the plastic plugs, threads were full of mud and surface rust. Had to tap the threads, 10x1.5, because the bolts just wouldn’t make it past the second or third thread All while laying on my back under the truck with not much workspace. Not too comfy, but got it done in about 5min and the plates bolted on no problem.Hiya Folks! @DaneJa is headed over my place to do the Skid Plate install on both of our vehicles. As he mentioned there are not instructions yet but I have been working with Owl's designer for the plates on a daily basis to work through some of the kinks. I think @MileHigh may be coming down as well to assist. I don't think it will be that cosmic but there are a bunch of steps such as removing the Gas Tank Skids and replacing some parts there...also we will need to support the transfer case when we replace the cross member. Other than that we should be fine!
I will say this though...I did install the Diff covers front and rear and they were a PAIN IN THE ASS! So Ineos put some plastic plugs to I assume help protect the threads in the factory holes. In principle this sounds OK but in practice it was not so fun. Somehow dirt and water got up into those holes and it took me over an hour to get them cleaned out to accept the bolts. It wasn't fun but at least they are cleaned out and the covers are secure on the Grenadier.
Well time for a bit of rest because tomorrow we install!
If you are referring to the aluminum skid plates....there are two options when you order from Owl. Bare aluminum or Black Powder coated. I elected to go with the bare aluminum because it was $400 cheaper and depending on where I hit a rock I didn't want to see the scratch.Awesome! Did @DaneJa paint his metal parts first?
