Just a question, do you get High Pressure warnings that will not stop? Mine warns me every 5 minutes or so and drives me nuts, it is as if the programer never envisioned this vehicle being driven on an interstate in Texas in the summer.
I have my tyres set on 36 cold and they get up to 44 after long highway runs in summer.
I set the tyre pressure sensor at 40 PSI and no problems
I find if the tire temperature gets too hot, it will not reset the pressure. it only works on "cold" tires. Maybe under 100 deg F?
I’ve not had a problem resetting on the fly but an alternative, if you are running 36-38, is to pressurize to around 40/42 psi when cold set the level then deflate back to “normal”.
Yes, exactly what I did.
It works a treat.
Only time I struck a problem when was ambient temperature hit 44 degrees Celsius (111 Fahrenheit ) and I was 3 hour drive on the motorway.
I had to reset the tyre pressure on the fly.
I realized after having a puncture that if you take the spare off the back, mount it and put the tire with puncture on the back, the system will replace the sensor of the non rotating tire with the new rotating tire. You don't have to drive around with the tire light on until you go have the punctured spare repaired or replaced.
Sharing:
BF Goodrich k03 275/65/17 on OEM 17’’ wheels,
Eibach +1,2 front springs
Eibach same size back springs
Lot of back and forth so will ask
Is anyone here running 285/75r17 on STOCK steel with no mods of any kind? Seems like people keep posting a photo and then say they have a lift. Looking for no mods.
I have had Toyo AT 285/75r17's on the stock steel wheels for about 5000 miles. No lift of any kind, stock suspension other than the King shocks. A lot of hard offroad use, like teetering on two wheels full tuck while turning, rock crawling, high speed dunes, with no rub at all. Spare clears the rear door. Just got back from a 2,500 mile trip with no issues. If you don't want to go full 35" tires and lift, these are the perfect size.
Take Backs.
On my MT 255/85/17 after a month, I experienced some rubbing on the right rear when it was fully articulated up. It was the plastic inner wheel well, that I could push out of the way easily. So I drilled a hole and put a cable tie to pull it back about 1-½".
Take Backs.
Hmmm Could you hear it rub or did you notice is on an inspection? I’m running the same tires and have hear them rub and I have certainly had it fully stuffed. That said, I have not looked to see if there are any rub marks.
I still maintain that it is the perfect size tire for this truck on stock suspension
I have my eye on the Eibach spring lift and some KO3s to fill out the wheel well. While this thread is... lengthy, what's the general consensus of tire size after the Eibach springs are installed?
ETA: I see there at least three kits available; 1.2/1.7 inch, 2.5 inch, and 4 inches. Looks to be back to the Google Machine for me!
I've got the 2.5" and fit 35"x11.5" Nitto Ridge Grapplers with no issues.
I could hear something but never saw it until last time. It was only the rear right. It's isn't a big risk, the inner fender is flexible, there wasn't any damage. It just bugged me. And the driver side never rubbed.
what is the biggest tire you can fit with 1.7" lift up front and 1.4" in the rear? I'm planning to go HD springs in the rear and they are 1.4" at 500lbs, paired with 1.7" up front.
I have 33" on 18" rims today without any rubbing.
Good to know. Thank you.
After reading a bit, a lift would make the ingress a bit much more. The QM is my daily, so some semblance of use is required. Perhaps the notion of stuffing a bigger tire in there with stock springs might be a better option. Or go full send, get the 2.5" lift and fit some slider steps. Much to contemplate.
Slider steps for the win.
I use my Trialmaster as my daily as well. Hasn't been an issue for me (I think you just get used to it), but definitely a challenge for my elderly friends and parents. 🤷‍♂️
I’ll be moving up to a 34-35’’ tire size soon. I have two questions though.
1) Does the vehicle self correct for a larger tire size with regards to the speedometer reading or will I have to go to the dealer to adjust the software parameters?
2) These vehicles have some form of traction and braking control. Raising the vehicle can and will affect what happens when the software Nanny’s kick in such as when you are accelerating or braking while cornering. Has anyone noticed a big change with let’s say a 2.5” lift and 35 inch tires?
1) No. And I don't believe the dealer can correct for it. When my speed says I am going 75, my Wolfbox GPS say 78. So not a huge difference.
2) I have not noticed any difference, but with the 4% difference in tire radius, I expect there is something there. I have not noticed.
