Agree that any tire can fail when subjected to such conditions, but there were multiple other of the same vehicle running together on the same trails, with different tires that didn't. Once, easy write off, more than once, starting to form a concern (for me anyway)..
In my experience tire failures have more to do with the driver than with any specific tire model. I have a friend who is always getting flats regardless of the tire he is running and other friends who go years with out punctures or failures.
[QUOTE username=Ferrugenfish userid=9004165 postid=1332800035]Okay so it's good to know that "minor trimming" is required to fit 35's... ground clearance is not impressive and needs a little help. It sounds like one would need to upgrade the springs/dampers and probably control arms and give it a decent lift in order to fit 35's to fit without cutting in order to get both increased travel and ground clearance.... which is a shame. IMO, Ineos should have expected people to want to fit 35's... but hey, 33's don't suck, and as noted above, 35's might not even fit on the rear door anyway. Looking forward to someone trying all of this and finding the best solution to maximizing ground clearance without screwing up articulation/geometry.
In all honesty, INEOS hasn't built this as a bronco/wrangler competitor. 35s are not needed for any workplace, overland trip, or other utility usage. The only place where big tires are NEEDED, are arctic expeditions etc. I had a wrangler on 35s, it looked great, but realistically never needed anymore than 33s to go anywhere.
35s with a small lift etc is still better than most other 4x4s. but ill be sticking with 33s on mine!
[/QUOTE]
Agree, ineos developed the portal axle version for serious lift. Otherwise just go 33s.
[/QUOTE]
That might be true in your local area but I can assure you that you need 35” tires in the western US on a lot of trails.
I’m curious if these tires that do not require any lift, have much/if-any affect on steering?
I am pretty new to the forum and looking to purchase Grenadier soon. The first thing I want to change is tires and might even build it into the deal with the dealer.
I have read through the posts and wanted to verify a few things and I am not an expert on tires and tire sizes.
I think my number one option currently are the MT 255/85r17 which I think measure just under 35 inches. I had read and seen on YouTube that 33.4 was the max you could go without having issues with the spare etc.
If I decide to go with 33’s, what would be the top recommendations for that size with my priorities being quiet at interstate speeds, smooth ride, and a tall (as possible) more narrow tire?
Thanks for everyone’s help!
Johnathan Benson at Tire-reviews.com does the best tires test available on line. The most recent test for AT tires in the snow is also really good. Definitely happy about my choice of the Mickey Thompson Baja Boss AT after seeing the review.
View: https://www.youtube.com/watch?v=LS8JI2FD6-o
I recently purchased the MT’s as well, initial impressions are great, though no snow yet.
For those that’s have changed to the 255/85’s what is your calculated (not infotainment measure) miles per gallon (US) compared to the original 265/70’s?
14.5mpg driving I-70 Boulder to Moab, 12.5mpg driving overland ~400mi Grand Staircase Escalante, UT w/MT.
16mpg Boulder to Moab on I-70 with stock K02
Both with Owl Roof rack
I get about 14.5mpg with a typical mix of driving
And thanks for these replies. I’m at 16.9mpg (calculated over 10k miles) on stock Bridgestones (which are super light and under-built). So I’ll take a 2+mpg hit when I go to 35’s.
No 255/85s, so not a proper answer to you.
Here's a good answer for 255/80: 13.9mpg with factory 265/70, 13.45 mpg with 255/80. That are the averages for 25kmi with factory and 15kmi with 255/80 - including everything from slow two-lanes to interstate to SoCal traffic and to rocks and sand in low range.
In the past trucks in my experience, the mileage decline was nearly inverse to the tire size - so my guess is 13 flat for 255/85s.
The MT also just work great. I didn't buy the Gren for its gas mileage, and I didn't buy the MT for gas mileage. They have great traction, and a good ride. Get out and have fun.
I'm just waiting for a little more clarity on the driveshaft failure warranty, and for the ability to clone/replace the TPMS so I can rotate the big MT's at my leisure.
(y)
