Do you mind sharing some pictures of what part your trimmed and how it looks? ThanksWhen I installed mine I used a washer and some spacers I bought from Lowe’s. They placed the table barely past the plastic access door, so I ended up grinding off the top portion of the bottom back piece to allow access. The ground-off edge sits below the bottom table piece so it’s not visible. I wanted to have the table sit as flush to the back panel as possible. Great buy!!!
So I printed some new, non-threaded spacers. Takes out the need for the washers and threaded spacers.
I’m happy with it as it- but you can see that the spacers I printed a bit shorter, which I thought would be fine- but… since they are a bit shorter, it makes getting the storage panel a little hard. With the standard Black nut spacers, how accessible is the plastic door? I think I’ll Print out ones a bit longer to make the door more accessible?
What is are the Velcro strips for?
