Inexpensive rear door table $88
Thank you both, that is great news since there should be no problem. I'll get one ordered quick, before the price goes up again!
When I installed mine I used a washer and some spacers I bought from Lowe’s. They placed the table barely past the plastic access door, so I ended up grinding off the top portion of the bottom back piece to allow access. The ground-off edge sits below the bottom table piece so it’s not visible. I wanted to have the table sit as flush to the back panel as possible. Great buy!!!
Do you mind sharing some pictures of what part your trimmed and how it looks? Thanks
The spacers I used spaced the table just beyond the bumped out portion of the door, without rubbing the plastic panel. In the pic you can see where I used the grinder. Yes I’ll be painting the edges, I just haven’t yet. The removable door just barely slides in and out perfectly. I wanted the table as tight as possible with leaving scrape marks.
I got one of these for Christmas so I’ll be installing tomorrow🥳. On initial inspection, it seems pretty well made. For 1/4 the price of some of the others on the market it would have to be pretty bad to not be a good buy.
